Adding remote locking "how to" FAQ
Received 1,236 Likes
i been sayin that for years!
put any factory stock XJS at a car show beside mine , and just watch the people stop and look and ask questions!
and to think i did that 26years ago!, did i mention its pretty fast also!
steve thanks for lettin me know!
Duke85 (05-28-2020)
Duke85 (05-30-2020)
What about the 1990
Hello all. This is definitely on my list, too...
Does anyone know what the cut off is. Meaning the relays vs the ECU control? I guess I could and should just go into my doggone 1990 electrical guide, bit thought I would just ask you guru's...
EDIT: I think I found my answer... Thanks for all this info non the less.
Duke85 (05-30-2020)
imitch1303 (07-01-2020)
#30
Hi,
I have just put this system on my 92 V12, https://www.ebay.co.uk/itm/373097262454 it has nice remotes that just to door open, close.
I just used the security system plug in the boot and was easy once I had worked out which wires to use on the new controller. My car was negative polarity too.
Function / Jaguar harness
Live / Brown
Ground / I used the ground bolt near the light
Lock / Orange/Red
Unlock / Orange/Blue
I couldn't wire up light flash as it works the other way, i.e. it gives a 12v pulse but what you need is it to ground.
Works a treat. Frozen locks in the winter are no longer going to be a problem !
Live / Brown
Lock / Orange/Red
Duke85 (07-12-2020)
#31
BadDog
11-23-2013 10:38 AM
BKSinAZ
03-11-2010 12:56 PM
