Adding remote locking "how to" FAQ
Old 05-27-2020, 09:06 PM
CZSteve's Avatar
So interesting side bar if OK for a slight thread high-jack...
So I'm on Amazon in the automotive section and have 1978 Jaguar XJS entered for my garage to narrow down selections and lo-and-behold the XJS picture that Amazon is using is @ronbros Jag - pretty cool.
The following 2 users liked this post by CZSteve:
Doug (05-27-2020), Duke85 (05-28-2020)
Old 05-28-2020, 02:00 PM
ronbros's Avatar
Received 1,236 Likes on 943 Posts
i been sayin that for years!
put any factory stock XJS at a car show beside mine , and just watch the people stop and look and ask questions!
and to think i did that 26years ago!, did i mention its pretty fast also!
steve thanks for lettin me know!
Duke85 (05-28-2020)
Old 05-28-2020, 02:57 PM
Duke85's Avatar
LETS SE THEN!!!! Lots of photos and details of your enhancements
Old 05-29-2020, 10:00 AM
ronbros's Avatar
pix will never take place of real life, a completely different visual reaction!
cars side by side makes a difference!
where the heck is Derby??
Duke85 (05-30-2020)
Old 05-29-2020, 05:57 PM
JayJagJay's Avatar
Received 1,296 Likes on 897 Posts
Default What about the 1990
Hello all. This is definitely on my list, too...
Does anyone know what the cut off is. Meaning the relays vs the ECU control? I guess I could and should just go into my doggone 1990 electrical guide, bit thought I would just ask you guru's...
EDIT: I think I found my answer... Thanks for all this info non the less.
Duke85 (05-30-2020)
Old 05-30-2020, 05:54 AM
Duke85's Avatar
Where is the door lock control unit on a left hand drive car? Derby is a place you don't need to know about
Thanks guys
Old 06-30-2020, 01:25 AM
imitch1303's Avatar
Hi Duke85,
Check out Doug's earlier posts (#11 and #13). There is not a single control unit on your car. There are two relays (lock and unlock) that control the solenoids in your doors.
Cheers,
Ian.
Duke85 (06-30-2020)
  #28
Old 06-30-2020, 10:43 AM
Duke85's Avatar
I got it to work in the end! Success!!!!! I figured it out through trial and error
imitch1303 (07-01-2020)
Old 06-30-2020, 10:45 AM
Duke85's Avatar
All the wires were on the driver side.
  #30
Old 07-12-2020, 07:51 AM
lambo911's Avatar
Hi,
I have just put this system on my 92 V12, https://www.ebay.co.uk/itm/373097262454 it has nice remotes that just to door open, close.
I just used the security system plug in the boot and was easy once I had worked out which wires to use on the new controller. My car was negative polarity too.
Function / Jaguar harness
Live / Brown
Ground / I used the ground bolt near the light
Lock / Orange/Red
Unlock / Orange/Blue
I couldn't wire up light flash as it works the other way, i.e. it gives a 12v pulse but what you need is it to ground.
Works a treat. Frozen locks in the winter are no longer going to be a problem !
Duke85 (07-12-2020)
  #31
Old 07-12-2020, 08:09 AM
Duke85's Avatar
Great well done. Mine is all under the D/S dash as I have an older model. But yes it's really made a huge difference. I use my car daily and this feature really brought the car into the 21st century!
Asdrewq
08-11-2016 06:18 AM
AfricanJag
10-10-2014 04:13 AM
BadDog
11-23-2013 10:38 AM
jjf
10-23-2013 04:30 PM
BKSinAZ
03-11-2010 12:56 PM
Quick Reply: Adding remote locking "how to" FAQ
