Adding a third brake light
I have been trying to decide the best way to add a third brake light to my 85 XJS. I found a trunk mounted brake light from a convertible on e-bay.
Is there an auxiliary wiring harness (usually used for trailers)?
Should I modify a trailer wiring Kit?
I have been told or have read that it is not a good idea to tap into the brake light wiring due to the bulb failure relay may fail or become damaged.
Any ideas? Thanks
Any ideas? Thanks
I like this one:
BackOFF? XP Brake Light Module - Signal Dynamics
mode 2 is almost legal. the law allows 4 flashes not 5. but who's counting?
following drivers inevitably go around or leave more space. either one is fine
by me
by me
I have recently added one. I used a very svelte light made by Hella, bought here:
Surface Mount Slimline LED Third Brake Light Red Lens - Car Builder Solutions - Kit Car Parts and Accessories
It is illuminated by LEDs, and is only about 1/4 inch thick and sticks on just below the boot lock channel above the number plate. I ran a wire from the LHS brake light cluster along the boot lid and through a small hole I drilled behind the LED. The whole thing is waterproofed by the 3M-type peelable adhesive the light is backed with. As it is LED and so practically no current draw, the brake light failure warning system does not even see it, so no worries there.
![Name: IMG_0713_zpsfizb5akg.jpg
Size: 219.9 KB](https://www.jaguarforums.com/forum/attachments/xjs-x27-32/154281d1501209043-adding-third-brake-light-img_0713_zpsfizb5akg.jpg)
A really good safety mod IMO, and much nicer than the guastly OEM boottop module.
Greg
Greg
FastCat85 (07-01-2015)
The following 2 users liked this post by plums:
anyoldiron (10-05-2019),
I paid my dues Plums! 40 years man and Boy, on my back with crap falling into my eyes! Bought it as a retirement present to myself, MUCH better value than a cruise, and amazingly not that expensive. And it is quite wonderful!
Greg
Greg
I'm sure it is. I used to have the run of an eight bay dealership
garage. Alignment machine, brake lathe, and every special tool
known to man. Several decades ago.
Used commercial units are available around here any day
of the week, any week. Cheap!
The problem is not having space to install it.![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
... some day ...
... some day ...
FastCat85 (07-04-2015)
Greg
Your original answer was better.
It is too much to expect following drivers to actually think.
Your reverse lights are above the add on, but if using for third brakelight,
they had better be RED and BRIGHT.
White festoons can be had on ebay very cheap and very bright if you buy
the right ones. It's a matter of led count and orientation. Red, I don't know.
KarimPA
09-12-2015 08:15 AM
