Aftermarket wheel horn wiring
83 model. I understand how the original steering wheel horn setup works.
The backside of my aftermarket horn button has the typical two prongs - one for “hot” signal and one for ground.
Simple enough, but I’m wondering how others have managed to connect a wire from the hot prong to the brass piece at the end of the rod that goes down the column (pic below for clarity). The brass end is really just a little nub, though there is a hole in the middle. Silly as it sounds, perhaps a small sheet metal screw can be used here…brass is pretty soft last I checked.
A soldering job or is there a cleaner way? Thanks
The following 2 users liked this post by jal1234:
Greg in France (11-14-2023),
MrAndersonGCC (11-13-2023)
MrAndersonGCC (11-14-2023)
