air pump
Out of curiosity does anyone know the CFM output of the stock air/smog pump? and could there be any benefit to piping that directly into the rear air balance tube?
I'm trying to justify not taking it out right now as it's quite cold. I've removed the air rails etc and followed Grant's advice to remain hydrated with plenty of...fermented liquid...it went well but the pump ugh seems like too much effort right now.
Received 10,872 Likes
As to the boost idea, the pump only runs for 45 sec at startup, so apart from the fact it would do nothing useful, you would have to fix it so it ran continuously.
ronbros (03-19-2018)
Agreed.
ALL mine went in the trash bin.
Their amount of actual usable air at any usable pressure is near on zero.
Running one constantly would have it seize up way quicker than they do now.
Not hard to lift out, and FORGET about the 1" pipe running aft under the RH exhaust manifold. It CANNOT be removed with the engine IN the car, unless you cut it up obviously. I strapped mine back out of the way, so it did not short out the alternator +ve terminal, and waited until the engine left the engine bay, then removed it, and gathered up ALL the errant tools dropped into the area over many years.
I replaced the pumps with a Jaguar idler arm and pulley, coz I stole a few as I found them in junk yards etc, and moved on. If you stil find one and the pulley is missing, simply use the pulley from the air pump, THEY ARE THE SAME.
Greg in France (03-19-2018),
ronbros (03-18-2018)
Received 1,236 Likes
van; that hose is for the GM map sensor, mounted on the right side inlet manifold, it needs a direct non pulsing vac reading!
in the vee the only wires or hoses are for distributor electric and GM vac advance control!
at very rear is oil sender wire, thats it simple and functional!
of course the nightmare hi tension leads, YELLOW!
like Grant; any thing that dont help to run the engine is done away with!
Grant Francis (03-19-2018)
Andreas Schmieg
04-16-2023 10:49 PM
kthrash
06-03-2011 09:49 AM
AntixSD
04-03-2010 07:40 AM
