Air pump system removal
Hi all,
i am removing the ( inoperative) air pump system from my 78 injected Daimler Double Six.
i have researched past articles on this forum but still have some questions.
the engine is stripped down to the cam covers. Most submissions indicate plugging the inlet manifold. As the manifolds are off the car would it be easier to tap and insert grub screws into the head?
I guess I will have to retain the air pump in some form as an idler for the vee belt?
any tips greatly appreciated
al
al
Hi all,
al
al
The air pump could be gutted for idler use or you could try getting hold of the idler from non airpump car, much neater.
Alan Lindsay (05-27-2018)
Sehr geehrter Herr Daim,
I trust the XJS forum is not too exclusive for a humble saloon contributor and your suggestion a polite request to remove myself from it.![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
The reason this and other questions are posted in the XJS forum is that there is a far greater percentage of V12s here than in the XJ forum. Indeed the car is an XJ by another name but engine wise, I believe I will have a greater expert readership here.
I trust this answers the question.
Mitt herzlichen Grussen
Alan
Alan
Alan
Alan
I was just wondering but okay, keep in mind that the engine may be the same, but the engine bay is a lot more cramped. So a job which may be easy on the XJ can be a LOT more complicated and awkward on the XJ-S. Just that you are aware of this. And as the XJ-S also had differences in the engine itself, you might get wrong answers... Just saying though... That is why I asked.
89 Jacobra (06-04-2018)
If you really want to ditch the air pump, there are two ways of going abut this:
1: remove the pump and get a shorter belt to go to the AC compressor and crank without the need of an extra idler. Build some metal brackets to use as tensioners and tension via the AC compressor.
2: remove the air pump and buy a European/British idler. I have one on my V12 from factory. New bearing, clean it up a little, done.
Alan Lindsay (05-28-2018)
Dear Daim,
No offense was meant.
Thank you for your interest, I do appreciate your reply.
I fear you may have mistaken humour for sarcasm, let's put it down to cultural differences. To us Antipodeans, complete with our self deprecating sense of humour, the economy of your question did demand humorous response.
kind regards
Al
kind regards
Al
Would you be sop kind as to give me some links to Jag salvagers over there?
Sure, no problem. Try Ben from Simply Performance or Andy from JustXJS. Both have loads pf used parts. You'll want the lot though. Pulley, tensioner arm, adjuster rod, bracket and important: a new bearing. They are readily available.
Fla Steve (05-28-2018)
kthrash
06-03-2011 09:49 AM
AntixSD
04-03-2010 07:40 AM
