air rail delete.
im just happened upon this thread....
is the air rail near the fuel rail and going across the rear of the valley and the air pump just an emissions thing??
what is this mod?
sorry dont have time to look into it about to leave for work just hoping for some info when i get back.
never really thought about it but always wondered wtf the "air pump" is for.
what is this mod?
Received 10,933 Likes
Yes
what is this mod?
Removing the air injection pump and associated plumbing either to de-clutter the engine bay or to avoid repairing a broken system.
Besides clogged air tubes, burned through check valves, and broken connector hoses you often have noisey or seized air injection pumps.
Many guys dump the system if doing so doesn;t run afoul of local emission inspections.
Some dump the system in search for more power...a fool's errand, IMHO. A properly functioning system draws maybe 2 horsepower due to the belt driven pump.
It injects fresh air into the exhaust ports on a cold engine.
The pump runs at all times but at the specified temp a diverter valve opens and simply vents the pump output
technically speaking the UK jags dont have an extra 20hp, rather the american ones are 20hp less potent.
smog/cats/EGR/ and the tune all play a roll in making the US spec jags less awesome.
once again, technically speaking, the UK jags are already ahead since europe has much better quality gasoline.
Yeah, a combination of various things....
The pre-Marelli, non-cat Euro/uk versions had 12.5 compression versus 11.5 compression. No doubt THAT comes into play, as does timing curves, etc
The cat converters themselves don't cost too much power ....providing they aren't clogged :-)
I what way is European gasoleine higher quality?
no kidding. i dont bother arguing anymore, because people who say that a cat doesnt restrict power, have never removed their cats.
i had a highflow flowmaster installed in my L67 swap car right before the swap to try and pick up some power. i tracked it and i was running 16's! i had only picked up a little over a second in the quarter from my old NA engine.
i did everything i could think of, higher lift rockers, ported and polished blower casing, ehaust work, etc. and nothing helped. i was desperate for more power and busted the catalyst out of the cat.
13.84!!!!!!!!
i picked up over 2 seconds by removing the catalyst, and that was on a car with computerized Knock Retard. on a car with no KR, it will simply predetonate and lose even MORE power.
