Air switching valve 1992 5.3l
I found a disconnected hose under the right-hand air filter box and have finally identified it as the hose from the thermal vacuum valve to the air switching valve. However, I can't find the connection on the air switching valve (which is behind the alternator, if I have the right valve). Does anyone have the same vacuum set-up? My air switching valve doesn't have a hose connection on the top like the one pictured in the attached diagram.
Paul
Paul
