Aircon blower motor
Aircon blower motor
Hi,
My drivers side (RHS) air con blower has stopped working except when you switch it to high. The blower occasionally comes to life for a few seconds but then dies again.
The LHS blower still works correctly.
From doing a bit of research it seems the Darlington transistor is the likely problem. So it seems I will have to pull the whole blower motor assembly on the drivers side. I've already got the instrument panel out and the underside trim.
Any other suggestions on what my problem could be before I take this job on? Thanks
