aj 8700 wire
aj 8700 wire
I am putting in an aj8700 inmy 88 xjs I have the code and all but the wire had been cut I have them all figured out but the antenna will not go so I jumped a hot to the white with trace for the antenna and it works .So is the blue wire the correct one and if so is my radio power out not working any one taken one apart yet
Ok, start again.
A lot of people have read your question but don't understand what you are asking.
Ask again, take your time and use some punctuation so that we know what you are looking for.
We are here to help but we can't help if we don't understand the question.
Is it about the radio/stereo?
Is the AJ8700 a Pioneer, Bosch, Subaru....?
ok I am bad at English I guess. I am going to install an aj8700 jaguar radio in my 88 xjs.I can not get the antenna to power on. I think that it should be the blue wire to power the antenna. Has anyone ever taken a radio apart to fix this problem. I know that the antenna works I ran a hot wire to power it and it works.
I think you should have a blue/red wire to the motor ('up' voltage) and a blue/white wire to the motor ('down' voltage)
The blue/red goes to terminal 5 of the relay and the blue/white goes to terminal of the relay.
This from an '87 diagram but should be the same, as the AJ8700 came out in 1987
Alas another problem the wire you describe was to the old antenna system. They changed it in 88 I think, no such wire exist from radio unit. So I am back to a blue wire that should power out to antenna I think But no power. I contacted a radio repair shop they want 400-500 to fix radio as new Guess I will have to think of this again.
The two wires I described were from the antenna relay to the antenna motor. Not from the radio.
I'll do some more digging but I don't recall a plain blue wire in either the earlier or later wiring schematics.
According to the site below, the blue wire from the AJ8700 is for a light dimmer, and isn't used on Jag's.
http://andthatsjazz.org/jaguar/forum...051726592.html
