AJ16 cooling won't keep up in heat
Ac issues
My car does not get hot , but the ac does start to fail if I sit in traffic on 100+ days as well, I was told the fans just cannot get the volume of air through the radiator to keep the ac cooling ,, it works amazingly well if I'm moving and my fan is running strong ... Just so much air can come through that small opening with the standard fan ?
Greg-
I actually have an aluminum parallel flow condenser. The car cools well until it gets stuck in stop and go traffic in 105 degree heat for 20 minutes. The mechanical fan just can't keep up.
The extra amps I want are just for my own peace of mind. I don't want to be somewhere late at night with my lights on, a/c on and all fans on and have the car die.
Spike
In this case, the system is just not doing enough air at idle. My own guess is that this is because the engine, even if you have the biggest alt known to man attached to it pushing the biggest fans, and the most wonderful a/c compressor, is just not turning fast enough to power them.
Why not do a test where on a hot day you set the idle to 1000 rpm (everything going, a/c, fans lights etc) and see what happens in a simulated hot traffic stop? Higher idle does a number of things: pushes the coolant round the engine faster, produces enough amps to power the fans, also, very importantly, makes the A/c compressor produce more cool.
One of those digital voltmeters plugged into the cigar socket will tellyou how high the idle needs to be to get the system up to speed.
Although my car is a V12, the fast idle solenoid I fitted transformed the hot traffic performance of the systems we are discussing.
Greg
orangeblossom (09-18-2016)
Greg, that's a good advice, the alt certainly cannot deliver enough amps and the battery will be under strain and voltage decrease when all the systems are sucking current at idle.
Two questions, though:
- that would require to put the gearbox in neutral whenever heavy heat conditions are met in traffic?
- with a good battery well charged, that should not happen unless the car drives for a long time in these conditions?
Greg
The following 2 users liked this post by Greg in France:
orangeblossom (09-18-2016),
paydase (09-19-2016)
al_roethlisberger
04-05-2016 10:55 AM
