AJ16 High Idle - Compilation?
It seems like quite a few people go through the TPS, IACV setups and still have the problem.
Look at it from the perspective of a new owner with a high idle. A search on XJS high idle came up with "About 237,000 results".
Where to start?
I was thinking of a single document explaining how the idle is controlled including diagnostic and troubleshooting procedures.
It would be a combination of info from the Engine Management System Manual, Service Manual, Maintenance Manual, etc.
If nothing else it will give me something to work on over the winter!
PDU can reset long term fuel trims, but that's about it. Resetting the LTFT won't have any effect on anything. It's simply a long average of the short term trims.
(I have a PDU)
There are 237,000 results because it's a common problem. The solutions are few.
I look forward to seeing what you put together, I'll be happy to help.
(I have a PDU)
Thanks for the offer to help. This will take me some time. A rainy/snowy day project.
I'll send you something when I actually have something put together..
It would be great if you would go over it and check, edit, correct, add to, etc.
Quite some time ago we talked about getting together to do a reset on my '96 4.0.
That didn't work out but maybe someday . . .
