AJ6 Cam cover gasket
I have a 1994 XJS 2+2 with the AJ6 4.0 liter engine with 51,000 miles. The original cam cover gasket developed a leak just above the exhaust manifold. I ordered a new gasket that on arrival was about an inch short when fitting it to the cover. i replaced the half moon plugs and was able to stretch the gasket and reinstall the cover. after about 50 miles the gasket blew out near the cam chain area. i ordered another gasket (still needed stretching) and put the cover back on torqueing the screws to the required inch pounds. Again it blew out near the same area. What am I doing wrong? The surfaces are clean and i'm not using any gasket sealer or cement. Oil pressure is normal.
It's a rubber gasket, so you shouldn't need any sealant. Could it be the supplier? I have changed that set twice without any memorable difficulties or resulting problems. It's not a cheap set though, I remember paying about $50 for it. You're putting the gasket on the cover first, right?
You said it blew out . Was there pressure causing it to squeeze out of place? Or is that just a turn of phrase? There should be a slight vacuum inside the motor....
Grant Francis (03-18-2020)
EsRay
12-08-2017 04:42 AM
