alr con gas pressure
You are not going to like this answer....
The service manuals only refer to a weight when recharging a AC system!
I don’t have my manual near me, so I don’t know what the weight is, but I probably have some posts that discuss it.
I don’t use the top up cans because they never come without sealant. I don’t want to introduce that into my system.
rgp (06-18-2018)
When I can't charge by weight, or using a refrigerant the system wasn't designed for here is my procedure:
Start charging until the compressor engages. Keep adding refrigerant slowly while spraying the condensor with a garden hose to remove the heat. Have the system set to full cold and fans on high. Watch the vent temperatures, they will fall as you add refrigerant and at some point the compressor should switch from running continuously to cycling.
At some point the vent temps will reach a minimum and then start to slightly increase. This is the point when it's fully charged. Both low and high side pressures will increase rapidly with additional refrigerant at this point, prior to this the pressure shouldn;t move much when adding refrigerant. With effective heat removal by the hose, you should be able to get vent temps down to the 3-4 degree range if everything else is in top shape. There is a thermal switch that should turn the compressor off when the evaporator core reaches just above zero, as you don't want the air to freeze.
As you are charging, also feel the pipes that run on the left side of the engine bay. This is the return to the compressor. It should be cool, but not cold. If it's cold and frosting that probably means it's over charged and you have refrigerant carry over from the evaporator. You don't want this, as liquids are incompressible and will damage the compressor.
The idea is when fully charged the evaporator core inside the car is full of boiling refrigerant, but not more, you don't want liquid to pass through the evaporator. The hot air inside the car should be able to completely boil all the refrigerant, so only vapour is returning to the compressor, by way of the fuel cooler.
I also have gauges hooked up to the system and keep an eye on the pressures. For my ambients I'm typically looking around 30-35psi on the low side, but I rely more on the vent temperatures. pressures will go up with temperature, that's why I use the hose to make sure I have very efficient heat removal. Without that the pressure will increase when driving and in standing traffic.
AC charging is a bit of an art, and part science.
The following 4 users liked this post by Jagboi64:
jimlombardi
05-09-2019 08:17 AM
1964Daimler
09-08-2015 11:54 PM
75Gremlin
09-23-2014 07:31 AM
Steve W
XJ40 ( XJ81 )
03-04-2011 11:24 PM
