Alternator Questions
I have been reading all the threads I can find on alternators. There seem to be a lot of differences of opinion. I want to get a new alternator and possibly move it to the air pump location which I would like to remove. I am hoping to find the easiest way to do this. What is the best replacement alternator and what needs to be done to relocate? (brackets, pulleys etc.) Will there be a problem driving the AC and Alternator with same belt?
Thanks for any suggestions...Jimmy
I got the GMALT from John's Cars... Jaguar XJS conversions, parts and advice from John's Cars ...and put a higher capacity GM alternator on (cant remember its power rating right now, but it's over 100 amps). His kit works as described, just bolt it on and provide your own alternator.
FYI, this leaves the air pump bracket free for when you decide to ditch the compressor in the V and put a smaller compressor where the air pump used to be. I used a Sanden from Vintage Air.
John
1987 XJ-S V12
John
1987 XJ-S V12
JayCee (01-22-2017)
Jimmy,
Most down here that fitted the alternator where you want, returned it to the OE position shortly after.
Their reason, not mine:
The tension required on the belt to drive the a/c compressor was too high for the alt bearings, and failure was common. AGAIN, what I was told.
I fitted a Bosch 115amp from an XJ40, and simply changed the pulley to a "V" to suit the standard alternator belt, and fitted it where the Lucas alternator was. I then removed that air pump bracket and replaced it with the Jag idler bracket and arm for the a/c drive.
OK, the Bosch and XJ40 are common down here, the GM, Delco, AC, etc are not.
Back in the early days when I was having alternator issues, I wondered who on earth put that thing in such a stupid place, but once I stopped messing around and replaced the Lucas with a Bosch, with upgrade, then I upgraded the wiring at the SAME time, I have never been back, and that was all done in 1996, and apart from a belt every 5 years, it is a forgotten item.
Your market makes decisions very different to mine, but I also looked at the alternator shift (I read The Book), but I reckoned it cluttered up that area, then the belt tension raised its head.
The following 3 users liked this post by Grant Francis:
The following 2 users liked this post by JTsmks:
Grant Francis (01-23-2017),
JayCee (01-23-2017)
Received 10,979 Likes
Replacing a failed unit or upgrading? I'm fairly sure that your '94 V12 already has a decent, high output alternator....probably Bosch or Nippondenso. Might be worth keeping.
The following 3 users liked this post by Doug:
The following 3 users liked this post by warrjon:
warrjon (01-23-2017)
After reading some of these posts, it may be easier to keep alternator in original location. I do want to get rid of the air pump. Where can I get an idler to replace the pump?
I saw a 120 amp Bosch alternator (reman.) at PartsGeek.com for $190. It is suppose to be a direct fit. Anyone have any suggestions on alternators (that don't require a lot of mods.?
Thanks...Jimmy
Just to throw out an alternative to buying something off the shelf.....
Over the last few year I have stopped buying off-the-shelf alternators and starters. Instead, I use a local starter/alternator rebuilding shop. Most towns have such a specialist. My experience has been very good with a 100% success rate versus 50% success rate with off-the-shelf rebuilt units
The following 2 users liked this post by Doug:
Greg in France (01-25-2017)
Received 2,399 Likes
Jimmy:
Don't fall for the fallacy of diagnosing alternator health via the dash guage. Notoriously slow and inaccurate. Not really gauges, but only indicators.
I made a patch cord for my VOM. Plugs into the cigar outlet. Much better data.
Volts in real time under various load and RPM's.
The Delco's can indeed be "clocked" to suit plug in and ear locations.
Carl
Carl
Jimmy...might want to keep in mind too that if you move the alternator to where the air pump is, or was, that puts the alternator in a place where it will get even less airflow than it does now. I think the alternator needs a decent amount of airflow to keep the diodes cool, and moving it further up *may* reduce the airflow to it, which may result in a failed diode (which I've experienced).
Just a thought.
Thanks,
John
1987 XJ-S V12
Just a thought.
Thanks,
John
1987 XJ-S V12
The following 3 users liked this post by J_C_R:
Just a thought.
Thanks,
John
1987 XJ-S V12
Just a thought.
Thanks,
John
1987 XJ-S V12
Thanks...Jimmy
With the air pump out, the alternator is so easy to get to that I will leave it in it's location. I am going to try the Bando 3430 belt solution for the AC and no tensioner pulley. Not sure if same length for the 94 as earlier models. I will check the length first.
I am considering how to plug the exhaust air holes for the air pump. I have read several solutions on this forum, and they all sound fine. I'm headed for Lowes this morning for parts.
With the pump removed, I will have an engine code, any way to stop this? The electrical wire that went to the pump clutch, should it be just taped off?
Thanks guys.....Jimmy
