always on fuse/power?
Going to add a dash-cam hardwire kit to my car, electrical isn't my strong point so I thought I'd ask here. On this year/model the cigarette lighter is not designed as an always-on power source, I have an add-a-fuse kit has anyone else done it this way with accessories? I (think) brown wires are always a good power source but I'd rather not start digging around and cutting things up just to splice in a tiny dash cam. The idea is to get a power supply for when the car is parked as well as when the engine is running.
Do you have a multimeter or any other way of measuring voltage? If so, ground the black lead and use the red lead to check the fuse box under the driver's side dash, as well as the one under the dash on the passenger side. Just go from fuse to fuse and find one that gives you 12 volts when the ignition is off. I wouldn't rely to much on the color coding as who knows what has been *modified* by a previous owner.
Thanks,
John
1987 XJ-S V12
Thanks,
John
1987 XJ-S V12
Thanks, I'll have to review the book right after I find my box of wine.
I'm aware of the power in the engine bay but sadly my dashcam cord won't go that far as I'd have to go from the windshield down and around to the footwell then up the passenger side rubber boot opening and back over its a tad more then the 4ft? cord I was provided.
![Icon Bricks](https://www.jaguarforums.com/forum/images/smilies/icon_bricks.gif)
MySTypeAteMyRX7
12-18-2012 02:43 PM
wnlewis
XJ40 ( XJ81 )
02-09-2009 10:47 PM
