Am I running rich, or is this normal?
'85 HE with Lucas ign.
Car really runs beautifully. I don't want to go changing anything for fear it'll just run worse.
However, I THINK it may be running a little rich, can you tell me if what I'm seeing is normal:
- Very low power and bogging when cold (have gone through a great deal of troubleshooting on this issue with NO progress)
- Raw gas smell at startup. I do tend to turn the key on and let the fuel pump pressurize the system before starting. Fuel injector hoses confirmed NOT leaking
- Black specks all over my new paint on the back of the car. Sooty.
Some things I've done in the last year, not really to solve this but more because it's almost 30 years old:
- rebuilt dizzy, confirmed everything working
- rebuilt vac advance control system
- full tuneup, plugs, plug wires, cap&rotor, etc.
- Verified CTS, IATS, TPS working properly and adjusted TPS to spec
- set throttle plates and linkage as per the book
- rebuilt AAV (this still doesn't really work, but at least now it closes fully)
- replaced SAV
- rebuilt wiring harness to underhood sensors
- checked FPRs, at least as of this past winter no fuel inside
Can someone tell me exactly where to check timing and how to adjust it? Seriously, is the only way to check it by lying under the car and the only way to adjust it is by disassembling the dizzy and loosening the flathead screws that mount it? I haven't checked or adjusted timing yet because I can't believe they make it that hard and I figure that can't be the right way. Although, it is a Jaguar...
Is there any real way to check for a leaking injector? If I have a leaker it could be filling a cylinder with gas explaining the smell on startup, right?
Thanks,
D
- replaced SAV
Thanks,
D
Procedure in 'the Book' is the best way forward...
Cheers,
- Will
Received 10,920 Likes
What about the feed and return hoses? Raw gasoline odor suggests a leak "somewhere" or severe over-fueling
Pull a couple spark plugs and see how they look. That would be a more reliable indicator
Good that they're not leaking but that doesn't mean that they're controlling fuel pressure properly. Over-pressure will cause over-fueling. A fuel pressure test might be in your future
Yes.
Not all that bad. Drive it up on some ramps, have a helper hold it at 3000 rpm, crawl under and check timing. If no helper available you can jury-rig the throttle open using some wire or other MacGuyver-ish method.
No!
They didn't :-)
There's an adjuster on the side of the distributor body. It's been years but as I recall it's towards the front. If you were standing at the right fender looking at the distributor the adjuster would be at about 1:00 o'clock.
Thanks,
D
Thanks,
D
You'll need to attach a fuel pressure gauge (a PITA), pressurize the rail, and then clamp off the supply hose. If the pressure drops, you have leaky injectors.
Or pull up the entire fuel rail intact and then pressurize the fuel rail and see if any of the nozzles are dripping
trosty
26
12-18-2022 06:40 PM
rsa760041
23
09-25-2015 01:33 PM
kevo
09-08-2015 09:45 AM
