Angies Water Leak
How do I know if the fan clutch is no good? I have 2 fans in the front of the car under the car under the hood. 1 runs constantly, the other I believe is for AC which I don't use and is shut off in the car so it doesn't spin. ( on the drivers side)
Based on this you need to replace the fan clutch as well.
Oil pressure will go down as the engine heats up this is due to the oil becoming more viscous as it walms.
Warm the engine up then turn the engine off and the fan should only rotate 2or 3 turns, mine used to turn 4or 5 times and I used to overheat in traffic, the car cooled down again once above 40km/h
Yes the fan clutch is on the right side. It is the mechanical fan run by the belt.
The fan on the RH side driven by the engine belt has a viscous clutch, what the clutch does is vary the power to the fan. The clutch has a fluid in it that as it heats up provides more drive to the fan. If this does not work properly the car will over heat below 20-30km/h. Once you start driving faster the air flow through the front will keep the car cool.
Oil pressure in the V12 is very low at idle, my gauge sits almost at the bottom and as you rev past 1500rpm the gauge will move up. This is normal. Can you post what numbers the gauge pointer are on at idle and 2000rpm.
#30
Angie's v12 (07-03-2012)
#31
#32
#33
#35
OK... Diana's rad is leaking from underneath, so I have to have that fixed. My mechanic is sending it out to be repaired, we're looking for a rad now because I don't want a crappy aftermarket radiator. I'm so sad right now!! This is the biggest job my baby has ever needed. I've only had to replace lines for her. Now she's having an "operation".
#37
#38
#39
