The tray underneath the passenger airbag. It always pops open at the most inopportune moments and startles me. The one currently fitted is a replacement, as I thought the original was not latching properly.
does anyone else have this problem? Is there some sort of aesthetically pleasing solution to secure this really well?
I can't show you on the actual Car, as She's all bedded down in the Garage at the moment but these Photos should explain it far better than I can
The Green Wall Plug (comes in various sizes) you can probably get them at Wallmart goes in the Hole in the Car which is already there
Then a Self Tapping Screw with a Washer, goes through the Tab on the side of the Shelf (which also has a Pre-drilled hole) and then into the Wall Plug you inserted into the Hole and then just tighten it up with a Screwdriver
Thanks OB, but the passenger side knee panel does not have that hold down, only the drivers....maybe I am not understanding ?
