Another "cranks no start" thread
I pulled the plug on the resistor pack. Ignition switch in the run position. I do not have any voltage on the pink wires. I have 9 volts on two the orange wires and 12 volts on two of the other remaining wires.
Do I have an ignition amplifier on this car? Should I be verifying that the small thin white wire is transmitting a signal, that it has continuity to pin 24 on the plug on the ECU located at the A pillar? (I do have continuity from pin 24 to pin 18 in the boot, at the injection module.
I've cleaned up the ground points on the car, all looked good nothing unusual.
Suggestions?
DaveS
Suggestions?
DaveS
Were they replaced with the proper Jaguar parts, or standard relays?? Those are both NON-STANDARD relays. When energized they should connect pin 30 to BOTH pins 87 and 87a at the same time.
Be sure to confirm that.
Cheers,
Do you mean you don't have 12v "+" supply voltage? You wouldn't, as those are on the ECU-side. The ECU takes them to "ground" to fire the injectors
You should, though, have 12v "+" key-on voltage on the pink/black wires at the injectors themselves.
I'm not sure off hand what accounts for the different readings but here you are reading voltage after is has gone thru the injectors
Since you have Marelli ignition, no, you don't have an amplifier like the Lucas cars did
To clarify, the ECU in the RH A-pillar is the Marelli ECU.
The ECU in the trunk is the for the fuel injection
When cranking (or running) pin 18 of the fuel injection ECU should be getting a "trigger" signal (12v as far as I know) from the white wire that comes from pin 24 of the Marelli ECU.
Good!
Suggestions?
I'll do some mulling. Hopefully others will chime in.
As I interpret things that's a problem, yes. You should be getting an "OL" reading....infinite resistance; no continuity.
That should be a shielded wire...sorta like a coax cable in apperance. Is the shielding making contact with the white wire?
Voltages
I pulled the plug from one injector and found that I have 12 volts on both pins. I will check all the injector plugs tomorrow, will report.
I do have the proper relay on the red "relay holder" I do have an improper relay on the other relay holder (it switches between 87a and 87) I do not, however, have any terminal in the 87a slot. (the 87 slot has two brown w/white wires......one for the fuel pump and not sure right now where it goes, right now) It all matches the wiring diagram that Doug sent to me.
The fuel pump starts for 4 seconds and stops, if I don't crank. I have easily over 30 psi at the pump.
I measured the voltage, at the resistor pack, from the plug, that was removed. I don't know why I had two orange wires that gave me less than battery voltage.
I talked to a radio communication guy......he said that the 4.16 M Ohms, on the wire from pin 24 to pin 18, was extremely negligible. I will however spend more time on this to verify that there is not contact with the shield.
I tested the TDC sensor and the flywheel sensor, I have 692 and 708 ohms, respectively. I have .030 clearance between the sensor and the ring gear. I have .030, .045, and .047 clearance on the "fingers" on the harmonic balancer. (I was told that the .045 and the .047 clearance may be excessive)(thereby not giving a proper signal to the Lucas?)
I verified that I have good spark from both coils, I cranked for eight seconds....both coil leads gave good spark for the entire eight seconds.
I have 3 to 4 ohms of resistance on the water temp sensor.
I hope I covered all the questions/statements.
I will re-verify the resistor pack readings.
Thank you all for the help so far.
DaveS
DaveS
My earlier remarks were confusing.
It's normal to have 12v + on boths sides of the injector, key-on, engine off.
With the engine cranking (or running) the ECU side of the wires gets switched to ground
My mistake again. Earlier you posted 4.16 m ohms. I interpreted that as 4.16 Megohms (capital M) but I think you meant what you typed: milliohms (small m). I wouldn't worry about 4.16 millohms either.
Although you just now posted M (mega) ohms. :-)
I'm no help on the crank sensor specs
Measured across the pins, right? At what coolant temp? Since the engine isn't running/won't start I would expect less than 100ºF
The spec is:
Coolant temp Resistance (kilohms)
32ºF 5.9
68 2.5
105 1.18
140 0.60
176 0.325
#28
16 Lucas ECU
Gents, Sorry about the lack of updates. I sent my Lucas ECU off to a friend in South Carolina, to try it on his car. His car started right up with my ECU. I will verify the Ohm meter numbers on the coolant temp sender, I will also verify the numbers on the wiring from the coolant temp sender to the Marelli. Will report back. I should have the Lucas back on Tuesday. Thanks DaveS
Ohm readings - 89 XJS Cranks No Start
I checked the resistance on the CTS, coolant temp sender, I have 2200 ohms. I then checked the yellow w/black wire from the CTS to pin 19 on the Lucas ECU. I had 169 ohms. I checked the other wire, I had .7 ohms (that goes to pin 5 on the Lucas) I probably need to replace the yellow w/black wire. Has anyone done this before. Do the threshold plates clip in place, can I access the wiring harness under it?
DaveS
DaveS
