Another Whatsit?
That is air intake vent for distributor. Do not plug it and you should check it and it's pair are both intact.
JayCee (11-23-2015)
That is the air filter to goes to your distributor cap.
There are two hoses to the cap. One is a vacuum hose and the other is a vent with a filter on the end. Air is drawn into the filter from the vacuum.
One end of the filter has a hose that connects to the distributor cap. The other end of the filter has no connection. The filter and hose are usually tie-wrapped to the underside of the firewall to fender bracing strut.
Mark
Mark
JayCee (11-23-2015)
Varies slightly according to ignition type (marelli verses lucas) but both hoses run from distributor with one connecting to T connector between extra air valve and LH air cleaner backing plate and the other is the one you have in pic.
JayCee (11-23-2015)
richzak
10-29-2015 08:22 AM
