AntiLock Brakes
Received 10,916 Likes
I had that problem once.
The toothed reluctor wheel inside the right rear hub had come loose. The wheel speed sensor picked this up as a wheel speed problem....loss of signal, I guess. Only happened on left turns.
The reluctor wheel would no longer firmly press-fit onto the hub shaft. I used Loctite to keep it in place.
I'm sure there are other possibilities.
xjrjag
09-24-2015 10:08 PM
