Any help on this? Diff noise after new trans mount bushing.
I just finished up with a new transmission mount and now I have a horrid sound in the rear! Noise is there whether left or right wheel is spun. So either the drive shaft or differential has a problem. There was no issue before the mount replacement so I’m at a loss. U joint seems sturdy. If I put my hand on the rear seat it vibrates with the noise. I had to drop the exhaust but like I said it makes the noise if right or left wheel is spun. Posted on fb owners group and my next step is disconnecting the driveshaft and isolating that the noise is coming from the diff. If it is the diff why would replacing the trans mount bushing mess up a bearing or gear?
https://streamable.com/6fb4eo
https://streamable.com/twigrx
many years ago l had similar in my series 1 xj12 with jag 4 speed o'drive. I chased tail shaft changes, centre bearing changes and diff output bearing changes for what ended up being rear mount issue.
just happened to put some weight downward on the gear shift lever one day and the noises changed.
That's some 40 years ago but still remember in some detail.
l can't help with specifics but almost certainly something to do with the mount work. Possibly centre cotton reel/support spring issue.
I'm not sure if that... the sound is very rhythmic. If I spin the wheels it’s quite quiet but while driving (well obviously front he vids) quite loud
But sometimes a worn U-joint can make a clack/click sound. Maybe the driveshaft position changed a bit and the UJ is now operating at a slightly different angle and is in a sour spot, so to speak.
I'm not really sure, though, that the noise in the driving video is the same as the noise in the second video
Anyhow...
If you're 100% there's no other interference between something rotating and something stationary (drive shaft and exhaust heat shields, for example) then disconnect the drive shaft and see what happens. With the shaft disconnection manipulate the UJ in all directions. it should feel smooth as silk. if not, you may have found your problem
944xjs (09-07-2020)
The gearbox mounting when installed gives very little clearance between the propshaft at the gearbox end and the rearmost support plate. I am pretty sure you have the prop fouling this plate. Nothing for it but to loosen the gearbox mount support plates and centralise the entire thing carefully.
If that does not do it, then the rearmost support plate has to come off too. Did you manage to screw in the two bolts on this rearmost plate that attach up in the tunnel? If not, that will be the cause. I am talking about this bit, and the bolts that go through the holes at the top of the half moon piece into the tunnel sides:
https://parts.jaguarlandroverclassic.../brand/jaguar/
No reason that I can think of.
Anyhow...
Anyhow...
The following 4 users liked this post by 944xjs:
The following 2 users liked this post by Larry Louton:
944xjs (09-09-2020),
Grant Francis (09-10-2020)
The following 2 users liked this post by 944xjs:
Doug (09-09-2020),
