Anyone making fuel injector harnesses
Received 10,979 Likes
Can't say for certain on a '92 but on earlier cars is it alongside the RH wall of the engine bay, well forward. If you were to look on the RH wall directly across from the RH air cleaner snorkel inlet you'd probably find it
JayJagJay (10-15-2019)
Some day I'll have enough confidence to chime in, in a moment like this... Haha, I was about to say that...
kmarajh (10-15-2019)
Doug (10-15-2019)
ROk, so Ive traced my connectors down. The resistor pack is on the RH inner fender, near the fan shroud. It has 8 connectors, as shown in the first 2 pics. That makes sense as it is 4 dump resistors.
The injector connector has 6 connections. 2 positive feeds and 4 switched negatives. From this connector forward to the injectors is what I intend to replace.
Why did Jaguar place the resistor pack under the bonnet near the front of the engine. Cooling? To reduce transients to the injectors when the ECU clamps the grounds?
Resistor pack
8 pin connector on the resistor pack
6 pin FI connector
Flip side of the FI connector
Resistor pack
6 pin FI connector
