Anyone using waterless engine coolant?
Water pumps still fail, hoses still leak, gaskets get old, thermostats wear out. The problems the XJS can have are pretty normal, but the engine bay is so cramped hoses have to be disconnected to work on most things anyway.
Id just rather top it up wwith more 50/50 each time I work on it...just me though
Also and perhaps more importantly is the claim of zero corrosion. If true then this would help to lessen the chances of premature water pump failure and this plus the fact that the system is under considerably less pressure may lessen the chances of hoses/gaskets leaking.
Another valuable side benefit to all us pet lovers is that the Evan's coolant is non-toxic so your favorite four legged pal will not keel over if he/she licks up some spilled coolant. (A big deal for me as I lost a dog for this very reason some years ago
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
All grist for the mill.
Cheers,
Allan
In addition to which, ethylene glycol itself is corrosive. Most automotive antifreeze is 97+ percent ethylene glycol when undiluted. When the corrosion inhibitors are depleted, corrosion starts.
Received 2,263 Likes
I plan to park my car for the season so I asked the curator of my museum what they use during storage. My museum is not a car museum but they are the proud owner of many cars including a totally original, and operational, Ford T and John Lennons' Rolls. When he said Evans I began to research it.
Received 1,236 Likes
if you look into the original R&D of propolyene glycol as a coolant product, it was developed by the US military for the Black Hawk helicoptors, not to cool the engines , but to cool the complicated hydraulic systems!
they often were stored for long periods of time, only to be fired up for a full tilt blast of action, and its then you do not have time to change any thing in the coolant system.
HEY wait up, how many of the you remember alcohol for anti freeze coolant, they didnt even have ethylene-glycol for a coolant YET! late 40s.
but like some say; "to each his own poison".
I'm very sorry but there is no hydraulic cooling system in the UH-60 Blackhawk helicopter. In fact there is no hydraulic cooling system in any US Military helicopter that I know of. I have flown most of them. For over 20 years I was a Maintenance Test Pilot on the AH-64 Apache
The purpose of alcohol, Glycols and other additives to water is to lower the freezing temperature and raise the boiling point of the water. The Water is the primary coolant.
Glycols have good thermodynamic properties on their own so can be used a coolants or heat transfer mediums but in a car their purpose is to act as anti-freeze.
Ethylene Glycol is highly toxic and corrosive in it's pure state. That is why there are warnings on the bottle not to use it undiluted. Water/Glycol mixes have a far lower freezing point and higher boiling point than either alone.
Propylene Glycol is the heat transfer medium of choice in Solar Collectors as it is (usually) food safe.
The purpose of waterless coolants is to eliminate the water (with it's associated corrosion issues and its low boiling point) from the equation.
AllanG (10-17-2013)
no military units have any hydraulic cooling systems??? didnt know that when i asked a guy about the small radiator on copter was for he said cooling something.oh well!!
speaking about cooling cars, model Ts etc, back in the day,depression era, around Maine-NH, Canada, with no money to waste, guys for the winter, would fill there cooling systems with Kerosene sometimes called coal oil, run it no thermostats, all winter.
in spring drain and flush it,replace all hoses, fill it back with just water,and be off to work or what have you!
invention is the mother of necessity, gotta do whatcha gotta do.
i been using Evans since 1990s
#28
There is a radiator on the Blackhawk. It is located behind the main transmission. It has a fan driven by the Tail Rotor Drive Shaft.
This is called the Oil Cooler and cools the oil in the main transmission and associated components.
Engine lubrication is cooled with a liquid-to-liquid heat exchanger using incoming fuel to cool the engine oil. This is a rather small, self-contained unit mounted on each Engine Accessory Gear Box.
The engines themselves are air cooled. In fact, on the UH-60, and in particular the AH-64 Apache, this ambient air engine cooling is so good that mechanics will warm their hands on a cold morning by holding them in the exhaust. This is needed to lower the IR signature of the engines.
So perhaps you can understand my frustration with the overheating of an XJS. With proper air flow and the current cooling system there should be no reason for overheating. Instead we have a small grill area and no where for the hot air to go in such a cramped space. I'm actually tempted to cut into the hood and install small exhaust vents or route hot air exhausts from the "V" area to under the car. Even two 2" flexible vents would improve the total air flow greatly.
Right now I always reach down and unlock the hood every time I park. You would be amazed how much convection air comes out.
KarimPA
09-12-2015 08:15 AM
KarimPA
09-03-2015 07:32 PM
