Ask me them stereo questions!
Old 03-12-2015, 11:20 PM
Forcedair1's Avatar
Originally Posted by mtodd_adelaide
Can anyone please advise if the factory head units in the X300 and/or X308 have RCA outputs?
My 2002 XJR (X308) with the "Premium sound" system has no RCA interface of any kind, only Ai-net (Alpine) interface.
Cheers,
mtodd_adelaide (03-14-2015)
  #282
Old 03-14-2015, 03:10 PM
mtodd_adelaide's Avatar
Cheers,
Thanks, the AI-NET interface is a good start i guess. Do you know how to identify this capability? is there a specific head unit layout that identifies the 'Premium Sound' package?
Matt
  #283
Old 03-14-2015, 05:21 PM
Forcedair1's Avatar
Matt
I'm not 100% sure, but I believe that the LCD display on the radio may be larger for the "Premium Sound" cars because of the GPS display. Besides, at the left end of the trunk/boot, the Premium system should have both, the GPS disk player and the sound amplifier, even when only the GPS device may be in view. And, like I mentioned before, being Alpine brand, the "Premium" ICE on my 2002 XJR uses Alpine's AiNet cables between all of the system's devices.
Cheers,
  #284
Old 03-15-2015, 08:08 PM
freedom76's Avatar
My 04 xj8...smh. I took out the radio to install a dd. Didn't have the correct t harness..thanks ebay..now it works with no sound and doesn't recognize the changer. I've tried enerything...
  #285
Old 03-15-2015, 10:54 PM
racerboytwu's Avatar
Default 99 xj8
How do you know if you have a Harmon car stereo
  #286
Old 03-17-2015, 06:46 AM
ken11's Avatar
Default Navigation system
I picked up a navigation system out of a 2004 x that I would like to put in my 2005 x. I don't have the nav in mine, is it prewired? Anything to look out for? Thanks
  #287
Old 03-18-2015, 09:22 PM
snowball's Avatar
I have a '96 XJS, the radio/ cassette player are working fine, but I thought I should maybe clean the tape heads before taking it out this spring. After looking inside tape slot I think if it aint broke just leave it. Any suggestions, obviously I am not tech saavy.
Snowball
  #288
Old 03-19-2015, 09:28 PM
Forcedair1's Avatar
Snowball
Just out of curiosity, Snowball, it is obvious that if you are cleaning the tape heads is because you want to get the very best sound that the system can provide. However, aren't you more concerned with the magnetic tape's poor signal durability? Unless you're still getting fresh cassette recordings, wouldn't you think that the sound quality of tapes from the cassette era would, by now, be fairly flawed? It's too bad that car radio technology trailed electronics technology so bad. CD was in-vogue already by years when my '94 XJS was manufactured, yet, the only thing they could offer for the head unit was...magnetic tape, yes, unless you procured the CD changer, as well.. Anyway, this is why this was the first improvement I proceeded to introduce on my XJS: Changed the OEM radio with a CD radio. Have you considered this?
Cheers,
  #289
Old 03-20-2015, 06:53 AM
snowball's Avatar
No I just wanted to make sure the heads were clean, since I have only had the car a year. Yes I know a CD player would be the way to go, but to keep original, anyway I found a new head cleaning cassette and used it. Thanks for your help.
Snowball
  #290
Old 03-20-2015, 06:20 PM
Mash631's Avatar
Default Bypass amp
Hi ! Guys I need help with my stereo I put a new Hu aftermarket with harness metra but I don't have sound I read that I need bypass the Factory amplifier ...
i have jaguar 2004 s type with premium sound , the amplifier is in the trunk but Idk how bypass the amplifier ??????
Please help!!!!!!!
  #291
Old 03-25-2015, 08:58 PM
Stargazer XJS's Avatar
I just removed the stuck cassette from an Alpine AJ8700, and now the deck still thinks there's a tape in there so it keeps cycling between side 1 and 2. Any suggestions? I'd rather not replace it with a CD player.
  #292
Old 04-22-2015, 12:00 PM
xk8lattmaster's Avatar
my xk8 2001, radio does not turn on, I have just replaced the battery and everything works fine except the radio, any ideas as to how I could fix this myself?
Thanks in advance
Purplexed
  #293
Old 04-25-2015, 11:33 PM
Balco's Avatar
My XJ6 94 has a aftermarket stereo, but it does not support the CD Changer. Are there any aftermarket stereos that due have the 8 PIN plug-in to control/power the CD Changer?
  #294
Old 04-26-2015, 06:22 AM
malc4d's Avatar
Anyone know if the radios destined for parts far and wide are different and how, as the seem to have different part numbers ?
  #295
Old 04-26-2015, 01:09 PM
Oliver9218's Avatar
I apologize if this has a solution somewhere. I have been reading and searching...
Issue: 2000 VDP w/Alpine premium sound. Subwofer sounds terrible (blown?), very little bass in system. I had tweeters only when I bought the car. Replaced the factory amp and all speakers seem to work, but the sound is awful. All high end, some mid. I have the sub turned all the way down to stop the noise. (sub sounds blown)
Questions:
Where to get an OE sub? (or equivalent replacement)
Do I have more issues than just the blown sub?
Thanks!
  #296
Old 05-02-2015, 12:09 PM
firenfix's Avatar
Default XJ8 looses radio presets
Any idea why my 98 XJ8 looses radio presets after the car shuts off? I installed the radio a year or so ago and it seems like this just started a while ago (according to my daughter who drives the car)?
Thanks,
  #297
Old 05-02-2015, 06:00 PM
malc4d's Avatar
firenfix
I bet its loosing the constant live feed. Check the live fuse.
  #298
Old 05-03-2015, 07:20 AM
Oliver9218's Avatar
Questions:
Thanks!
Just ordered new door speakers. I am going to try that. Head unit seems to function perfectly. The sub is blown and sounds bad as well. Door speakers were easy to find. OE sub was replacement was not. After a bit of research i found this for the sub replacement:
Retrosound R 69N DVC Dual Voice Coil 6x9" 200 Watts Upgrade Replacement Speaker | eBay
  #299
Old 05-08-2015, 11:34 AM
fabfingers's Avatar
1998 xj8. We have fitted aftermarket did/sat nav/stereo unit.
We can't figure the direct wiring to the steering wheel controls - our SW wiring does not concur with the books or wiring info we hVe.
We have a plug at back of stereo that links to main harness and have empty pins there also have empty pins on the plug that comes from stereo. The stereo has a key 1, key 2 and ground wire coming from it but we not sure which pins they go to
Please can anyone help xx
  #300
Old 05-08-2015, 01:00 PM
DrScientist's Avatar
i currently have this head unit in my 91 xjs.
Decent Used Jaguar XJS 95 96 Stock Radio LHE4100FA LHE4100BA Head Unit | eBay
am i going to have to solder in a new harness if i want to change to something like this?
Pioneer CD BuiltIn Bluetooth Apple iPodReady InDash Receiver with Detachable Faceplate Black DEH-X4700BT - Best Buy
Quick Reply: Ask me them stereo questions!
