Ask me them stereo questions!
Stock radio
Does it pay to fix the old radio for the sake of authenticity or try to find a good working unit. They're not too bad sounding and are easily swapped for shows. Mine was weird, the AM was working but, the FM wasn't working so I found the PC board in question, re-soldered the (cracked connections), reinstalled and now the FM was clear but now no AM. Well plus when I checked out the changer it wouldn't push the cassette out so I shelved it. So whaddaya think? should I bother or buy, Thanks, Bud
Dave and Denver,
Thanks for the suggestions I appreciate the help.
Dave, I will get by the dealer and see if they can reprogram the alarm.
Denver, I have the ultra delux cheapo model Wrangler. The only on screen menu is at the drive thru.
Thanks again, Terry
Thanks again, Terry
Radio thinks car phone is off the hook
Dear Jake21,
I have 2002 XJ8. Radio light won't go off, radio won't play, because the radio thinks the car phone is off the hook.... Surprise...I don't have a car phone. When I call the dealer they say spend $1500 to replace the radio. Please help if you can.
Not quite a stereo question but related;
95 XJS with original OEM..Harada antenna
Original antenna motor gave up the ghost. Bought a Harada MX 22 thinking it would fit, but the top of the antenna is too large for the OEM Chrome piece. Is there an adaptor I can use ?
Thanks !!
Thanks !!
I welded rear quarter shut, where the antenna opening was. So now I am planning to fit solid antenna into rear bumper and blend its trim nicely with bumper chrome. Just a thought...
BTW, I have perfectly functional 82' Jaguar am/fm tape, which I pulled from my car in favor of Pioneer with USB connector.
#28
Jake,
This isn't Jag related, but, I thought I'd throw it out there. My DD is an '08 Jeep Wrangler. I am wondering if there is a way to disable the horn honk feature when you lock the car with the remote fob. I have never liked that on any car and I hate it when it's my car. I get home late a lot of nights, and I hate disturbing the neighbors. I don't really care if it also disables the alarm, nobody pays any attention to them anyway. You audio guys always seem to know about alarms.
Thanks, Terry
Thanks, Terry
Press and hold the Lock button on the fob for at least 5 seconds. While still holding the lock button, press the Panic button and release both. Test operation.
Do you have the Alpine System?
Pac-Audio.com Product Details | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
Well, I would first try to figure out why nothing has power, if you get a new system, you will still have the issue of not having power. Check fuses from car and fuses on radio and amp, and check for any fuses near the battery. If fuses are fine, get out the DVM and check for voltage, I cant even count how many times people have come into my work with a poor or missing ground (earth) wire so make sure everything is grounded to METAL, not another wire.
My OEM stereo tanked and I want to replace so I removed it and bought the wiring harness adapter from the UK that converts it to an ISO connector. Now I can't ind a stereo that has an ISO but only I guess what is the new standard a 16 pin. How do I figure this out and are the pin layouts universal across brands or do I need to match the brand to the config?
#30
ANY Aftermarket stereo will work, they all come with their own wire harness
(Make sure you double check the wires though, some manufactures change a color here and there but it is RARE)
Here is the most common aftermarket colors, which you ISO connector also most likely has:
P o w e r / G r o u n d
-Memory (+12v Constant) Yellow
-Ignition (+12v Switched) Red
-Ground (-) Black
-Power Antenna Blue
-Amplifier Turn-on Blue/White Stripe
S p e a k e r s
-Right Front (+) Gray
-Right Front (-) Gray/Black Stripe
-Left Front (+) White
-Left Front (-) White/Black Stripe
-Right Rear (+) Violet
-Right Rear (-) Violet/Black Stripe
-Left Rear (+) Green
-Left Rear (-) Green/Black Stripe
If you need help, PM me with a pic of your harness and the radio you are interested in getting, i can also guide you in the correct direction of a quality radio. I can give you a full walk-through of how to install it, after your done, you will be able to install a radio into any vehicle
#31
Thanks Jake21,
I have the adapter for the harness to get the ISO but now it seems I have to buy the adapter to the typical 16 pin from either Europe or Australia!! Are they not available in the US? I am looking at a Pioneer with Bluetooth hands free and the ability to turn the display green to match the dash. Any thoughts?
#32
[QUOTE=jake21;663315]With the doors closed,
Jake,
You're a genius! It worked like a charm. Thanks for the help! You saved me a trip to the dealer and most likely a few bucks!! Like a lot of the guys on this forum you've saved others a lot of work, time and money. I am always amazed at how much information and knowledge there is on this site and how willingly it is shared.
Terry
Jake,
Terry
#33
Thanks Jake21,
Also, upload a picture of the ISO harness you have so i can take a look at it.
And good choice on the Pioneer, they are good decks, is there a specific model # your looking at?
Jake,
Terry
Terry
#34
Thanks Jake21,
#35
Almost - the one I bought is a twenty pin but otherwise looks the same. Apparently the deck comes with the 16 pin plug and bare wires so that I can do the splice after the plug I bought and not cut the OEM wires. I bought a Pioneer DEX-H6500 BET as it got good reviews for Blutooth and iPhone connections.
#36
#37
Celebration '96 - Alpine stereo drops in & out
The original Alpine stereo in my '96 Celebration 4.0l powers on and off fine but at different stages over the last year I can't hear anything on any mode - cd/radio/tape from the speakers.
Now when I stop the engine, I can hear the music playing very faintly.
Every now and again, it will come back to life and work normally while driving. If I then power off the stereo before coming in and turn it back on when going out, it will work again most of the time. Though if I let the stereo stop when the engine stops, it generally won't re-start when I go out again.
I've checked fuses and taken out the stereo to check the connections at the back but no joy.
Any help would be really appreciated - thanks !
#39
Jake21,
Thanks for all of your info. I keep coming back to this thread. I have an interesting problem. My after market Alpine will work fine when just the back speakers are hooked up, however, as soon as I hook up the front speakers, they all go out. I still have perfect power to the head unit, but no sounds come out. Any advice?
Thanks,
David
Thanks,
David
Road Kitty (06-18-2013)
#40
I have a 99 jaguar vdp and I'm trying to install some subwoofers to it with factory stereo .. would you know which color wwires would I hook up the adjustable line output converter too?
