Auxiliary Fan Question
Received 10,871 Likes
The only problem with that is, what if someone else drives the car? Or what if your attention is elsewhere, such as an intense conversation with a lovely passenger or phone call or just spacing out enjoying the scenery?
A simple suggestion would be to order and install one of these:
Jaguar XJS V12 Auxiliary Cooling Fan Switch Upgrade
It causes the fan to come on at a lower temperature, and works quite well.
The only problem with that is, what if someone else drives the car? Or what if your attention is elsewhere, such as an intense conversation with a lovely passenger or phone call or just spacing out enjoying the scenery? A simple suggestion would be to order and install one of these: Jaguar XJS V12 Auxiliary Cooling Fan Switch Upgrade It causes the fan to come on at a lower temperature, and works quite well.
Mac Allan (09-22-2015)
Replacing the OEM fan with a modern top quality fan is probably the most important thing to do, in addition to adding a manual switch. As Doug said, it is not a good plan to remove the original circuit in case you forget to manually activate the fan.
Also, my feeling is that the fan should also be on whenever the aircon compressor is on, and this is an easy fix if your particular model does not do this. Jaguar changed their minds about this from time to time. Mine comes on OEM 100% with the aircon.
Greg
Greg
JJS- Florida (02-14-2024)
Just following up on this old thread, I have a 1982 V12- the auxiliary fan seems to run permanently when the aircon is on, and since the Delanaire system is automatic or nothing it is alway son when the heater/aircon is on. However, my ac has stopped working now (together with a horrible alternator belt squeal...) and I have noticed *no* auxiliary fan cut in. This is perturbing given the reputation of the V12 and also given that I have a 42 year old radiator & an abnormally low (i.e. not believable) dash temperature reading. The heating and thermostat work.
1. Is it normal to have no aux fan cut in but continual running with climate control?
2. If not, assuming I can wire the relay to the temp sensor on the water pump, is it recommended to upgrade the aux fan?
3. Does that same thermal sensor run to the dash display (I believe I have grounding issues as tacho, fuel gauge and speedo are erratic)?
4. Would you replace and/or upgrade the temp sensor?
5 . I dont want to budget for new radiator or main electric fan yet as I have other upgrade/restoration tasks in the immediate future, but maybe later.
Thanks a lot!
Matt
1982 HE
Thanks a lot!
Matt
1982 HE
There is a diagram out there that ties that aux fan to the AC Power. Turn on the AC, and the aux fan turns on.
This mod does not change the way the original fan was designed to run, so even if the AC is off, and the coolant demands that the aux fan comes on, it will.
Much better than a rocker switch, in my opinion, which can be forgotten.
The aux fan isn't designed to run continuously while the AC is on in any models. The wiring modification adds that feature to the way the fan is set to operate on all models.
With or without the mod, the aux fan should come on when the coolant reaches a certain temperature, whether AC is on or off. The mod simply adds a second way to activate the aux fan, which would be whenever the AC is turned on.
On many of the V12s, at least until 1989-ish....that's when some of the fan and compressor circuits were changed....the aux fan would, by design, come on whenever the a/c compressor was engaged. And....the climate control system was designed so that the compressor was engaged in all modes: cooling, heating, blend, defrost. So, for all intents and purposes, the aux fan was operating at all times unless the climate control was set to "off".
The following 2 users liked this post by Doug:
Grant Francis (02-13-2024),
I recall that the temp switch for the fan is calibrated to 94ºC. Your coolant might not be getting hot enough. Or....there could be an actual fault to trace and repair.
JJS- Florida (02-14-2024),
Matts73 (02-13-2024)
The following 2 users liked this post by Greg in France:
abonano
25
09-25-2015 10:43 AM
