b bank cat glowing red .....
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
Well I fired her over for a second time this week I have too play with the throttle too get her rolling doesn't like too idle . Thinking she would clean out I ran her up too 1500/2000 by ear for about all of 10 seconds I immediately shut her down when I noticed she was glowing pretty good . Im currently cleaning the swirl tank anything else causing my issues? Ran bmfine before she decided too pop and snort then shut off last year
orangeblossom (12-03-2014)
I'm assuming your car is an '88 which would mean your car has the old style Lucas ignition but this definitely sounds like a marelli failure.
Do you know what ignition system you have? One HT lead going to the center of the dist. is lucas and two HT leads going to the center of the dist. is marelli.
Are you familiar with the Marelli ignition issue?
The following 2 users liked this post by EcbJag:
88-xjsv12 (12-03-2014),
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
Well ok,
1) which distributor do you have...?
Marrelli (hint: two coils)
lucas (hint one coil)
2) if Marrelli
check to see if bank B is getting spark...
if Lucas...
make sure you do not have an injector on that bank stuck OPEN
GB!
The following 2 users liked this post by Jonathan-W:
Received 10,920 Likes
Careful!
Marelli cars had the two ignition modules above the radiator....that's an instantaneous identifier. Also, Marelli distributors lacked the vacuum advance cannister.
Or......
Marelli ignition was fitted beginning with VIN 156xxx (there's some conflicting info on the exact car number). If the VIN is well after '156xxx' then Marelli can be assumed.
The following 2 users liked this post by Doug:
If a cat is glowing red, then it is because it is burning raw fuel. This is almost certainly because one or more injectors are staying open.
This in turn is either because one is jammed open by crud (could be as you have not yet cleaned out the fuel delivery system) or, and just a likely, the injector harness is brittle/worn somewhere and is shorting to earth. If this happens at least three injectors stay open.
Take a careful look at the injector harness, and if you find brittle places or actual breaks in the insulation, renewing it is a must.
Greg
Greg
The following 2 users liked this post by Greg in France:
As above.
Also the LH FPR may have a ruptured diaphragm that will also suck raw fuel into the LH side of the engine.
If it were mine, and its NOT, I would be renewing the EFI loom, flushing the fuel supply and return lines a few times, just to be sure. New spark plugs (properly gapped). Test the 2 FPR's. Even remove the RH FPR (well documented in here on that). New fuel filter. New EFI hoses, ALL OF THEM.
Injectors cleaned whilst the hoses etc are off for renewing is up to you, and also based on the amount of crud you will find in the main and sump tanks. The time this thing has stood is certainly the brick wall you are now up against.
Then you are pretty well back to basics without the "grazing" effect of doing one thing at a time, and being forever at it.
Im doing the swirl tank as of now an big surprise shes a wee bit nasty . If I were too put a mixture of 50/50 kersone n marvel oil in the tank too let it flush the injectors this wouldn't hurt anything right? I've done it with hundreds of other cars but this is a jaguar we are talking about not taking any chances. I plan on upgrading and getting away from the entire lucas computer and distributor so re building fuel lines is close too pointless it just needs too run so it can be moved in and out of the garage until I have all the parts ready too go in.
If you are not changing the injectors, then ensuring they are working properly and not stuck open by crud seems worth doing now. Having cleaned everything, running some cleaner through must be a good idea. A substitute for cleaning, it is not. The Lucas system is actually very good and reliable, the reason your car is not running is pretty simple to find, as various posts have shown. A day at most would do it. Obviously up to you, but having a car running properly before you start changing systems makes sense to me, as if not, you never know whether your new setup is not working or if there are residual problems from before.
Greg
Grant Francis (12-03-2014),
I'll have too go pick up my compressor from the house . She was running perfect last year wouldn't rev higher than 3 without effort so I'm pretty sure the secondary coils burnt out. Good spark on both banks still. I'll run by the parts store in an hour or two I know the lucas is pretty reliable for the most part I'm just going too swap her out in a couple months its 30 years old cracked wires an someone elses hands have already been in here. Less headaches too swap it out because later down the road there will be modifications and eventually a rebuild of the motor .
Complaints, common sense, saw many of them fitted with the HE rail, and a single FPR on the LH side only.
My HE runs one FPR (a PreHE unit) on the LH side only, and has done so for 13 years.
neruda
10-18-2015 01:19 PM
Johnken
09-15-2015 05:46 PM
Dickie_L_J_O
09-13-2015 07:44 AM
