B post - exterior strip from door to roof
I'm starting to see quite bad corrosion on the b post pillar close to the door frame at the top left corner of the door (with the window down).
I had a close look at it earlier and it looks to be a removable plastic coated metal strip over the shell of the cabin.
Can anyone confirm this or is the exterior facia of the b post all one part of the car shell.
As it's caused by Irish rain
coming off the driver window and collecting at the lip where the b post meets the door panels, I'm hoping a water tight replacement part is available - does anyone know any sites selling the part and the part number.
Otherwise, I'll try and cut out as much corrosion, sand it and replace with a plastic metal compound and paint with hammerite.
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
