Banjo bolt for radiator
Hello all.
I am in desperate need of the banjo bolt, spacer and sealing washers that go on the right side top of the radiator on my 1990 XJS. I have contacted all of the known Jaguar spares suppliers to no avail. I will check with David at Everyday XJ sometime today.
The part numbers are as follows:
Banjo Bolt - C44085 2 .....superseded by # C440853
Sealing Washers - C4146 3 needed
Spacer - CAC 4559
If anyone has these items please send me a PM.
If there are any known substitutes out there please inform me. I know its some kind of weird thread so who knows.
Spacer - CAC 4559
This guy makes a much improved version as discussed in Kirby Palm's BOOK. Excellent seller, ships fast from Lithuania.
https://www.ebay.com/itm/32449396631...mis&media=COPY
The following 5 users liked this post by jal1234:
Greg in France (06-14-2024),
JJS- Florida (06-15-2024),
Mac Allan (06-24-2024),
RickE (06-14-2024),
uspurs (06-15-2024)
You really don't want the stock banjo bolt. They require special, very thin, copper washers so they don't restrict or completely block water and air flow. His is modified so that standard copper washers can be used, maintaining proper flow. It is quite common for the stock bolt passages to be completely blocked.
You can read about the issue in Kirby Palm's BOOK, available in the stickies at the top of this forum. It will answer most of the questions you've asked here. Highly recommend you download it and read it.
Jon
Jon
The following 2 users liked this post by jal1234:
@jal1234 Thanks. I have a paper copy of the Kirby Palm book. I only refer to it when I am not so sure about something but as a fact the contents of his book is purely his take on things based on his experience and the opinions of the others he always refer to. It is good reading though.
I ordered the Banjo bolt from the guy in Lithuania. Pretty expensive though. 40 euros. Delivery time unknown.
I also ordered the 3/8 to 5/16 inline fuel adapter in stainless steel from a Marine store near me.
Thanks so much for the TIPS you and Mgaur have given me so far. Really appreciate it.
There was a guy in Lithuania or somewhere making them and selling on ebay. Far superior to originals.
https://www.ebay.co.uk/itm/324493966...Bk9SR4LzvIqDZA
The following 3 users liked this post by rgp:
Jaguar repeated the thin washer issue on the banjo bolts for the oil feed lines on the back of the V12 heads. The same supplier of modified radiator bolts also makes improved versions of the back of head banjo bolts so they can use standard thickness washers.
Jon
Greg in France (06-25-2024),
JJS- Florida (06-26-2024)
Nacim Hamaidi
12-29-2017 12:08 PM
