Banshee... Have you seen this?
Received 9,336 Likes
Hi Alpecsa
After you have written your Post, Click on the Anchor Chain Symbol above and then this Box will open (see photo)
Where it says display Text just put a brief description ie Banshee Gas Station Fight Scene
Then if you haven't already done so, Click the Share button on YouTube and Click where it says Copy, which then Copies the URL to the Clipboard and then Paste it in to the URL* that has the Star 'Thingy' like the one I've shown here URL*
That is all you have to do, don't fill anything else in and leave the Protocol Box alone
Then having done that Click OK and all you will see is your Brief Description in 'Blue Text' and if you Click underneath that 'Blue Text' you can then add a bit more description, which should appear in 'Black Text' if you want to
But if you find it's still Typing in 'Blue' its no big deal unless your OCD though if you would rather have 'Black Text' Re-Click on the Page a bit further down and then you should be able to Type in 'Black Text'
But leave the URL* in Blue or you could mess everything up
If everything you've done so far does not make any Sense: When you hit the Button to Post the Repy (post your post) that's when the Magic will happen and the YouTube Thumbnail for everyone to Click on will be there for all to see
If possible have Two 'Tabs' open when you are doing this. One for the 'YouTube' Video and the other one for 'Here' on the Forum, so you can Switch between the Two, without the need to mess around with 'Back Buttons' as its easy to get lost as everything could start to fall to pieces
Good Luck
Alex Great Find! BTW
Good Luck
leep123 (02-26-2024)
Darrenmb
10-02-2023 03:22 PM
