Battery
Hi all I purchased my second Jaguar this one is a xjsc it a Jaguar Cabriolet it a project the 12v motor was bad so I transplanted a sbc 350 motor and trans and operation was a success my problem is I don't think the alternator is charging the battery I get 12v out of the alternator to the battery from the battery line going back to the battery but my gage just goes up a little just above the red line.. gas gage don't work either but that a story for another day so any help is welcome ..is there a site that I can go to for the electrical diagram for a 1987 Jaguar xjsc... Thanks for your time
Received 1,236 Likes
HI Warrjon,, a question, i just put a new alternator on V12 XJS,, seems to be charging at 14.3 volts measured at the alternator output terminal, but after a few seconds volt meter drops to 8 or 6 volts for about 1 second then back to 14.3 volts, like its cycling up and down!
any ideas that would help, battery measure engine off 12.5,, when running battery stays around 14.1/14.2 volts!
its a Mitsubishi alt ,but fitted OK, 3 wire internal regulater type.
ron
ron
Ground
Battery connection
D+ for the warning light / gauge.
Newer alternators can have more terminals for pulse outputs and a lot of other things. These newer alternators will still work on older cars and the extra terminals not used.
Greg in France (12-18-2018)
ron
ron
6-8 volts seems unusual, it may be noise interfering with your meter. Check the voltage at the RH terminal post. The alt wiring goes to the starter motor then to the terminal post.
You say that at the battery the voltage is steady @ 14.1 which indicates the alt is charging and the battery is not fully charged.
I would not be too concerned unless the voltage at the battery dropped.
ronbros (12-17-2018)
snkpkp
01-14-2021 09:52 AM
BigCat09
12-04-2019 03:06 PM
cat_as_trophy
01-26-2014 07:40 PM
Mark Scotton
24
01-23-2013 09:27 PM
Mccalist
12-14-2009 09:05 AM
