Battery Advice Please--'89 V12 XJS
Interesting, Interstate doesn't make a battery (or list one) anymore..
You can also try an Optima (they are sealed dry-cell so no venting required):
http://m.optimabatteries.com/#/redtop/specs.html
Just make sure the specs fit size wise. They do require a bit more babysitting in terms of maintaining a full charge, in terms of following their charging instructions if the car won't be daily driven.
The 34 /34R should fit IIRC, but double check.
Jeff
Jeff
Check the price on the Optima; which is a very good battery.
Venting is not a problem. Jaguar made provisions* for a plastic tube to exit the floor of the trunk. The battery has a fitting for the other end of the tube. Very easy.
I will get back to you on battery size.
*small hole
Back to you: It's a Continental Platinum, L3/H6/49-CP, 36 month replacement, cost a little over $100. Ask for venting kit; which is a short piece of tubing!
My car is a 93 coupe 6 cyl. and this battery works fine for me. Since you have a 12 cyl you may need more cranking power that is why I recommended going to the Continental web site, there you will find all info you require.
*small hole
afterburner1 (07-09-2015)
Charlene n John
09-28-2015 06:01 AM
OkieTim
09-08-2015 04:48 PM
