Battery or Alternator?
Old 08-08-2018, 11:59 AM
catterwaller's Avatar
If the alternator check out good and the belt and wiring are ok, Look at the damper pulley on the front of the crankshaft. A common problem is the rubber pulley mounting goes bad so the pulley slips on the damper. Symptoms are very much like a loose alternator belt. Easy to tell. Mark a line on the pulley and damper with chalk, paint marker or silver sharpie. Go for a run and check to see if the marks are still in line.
jxjsv12 (08-09-2018)
Booty1313
12-23-2012 12:43 AM
thuffner3
05-27-2011 10:06 PM
Willchill
01-18-2011 08:39 PM
BrightonRay
11-30-2009 12:20 PM
Quick Reply: Battery or Alternator?
