Battery or Alternator?
If the alternator check out good and the belt and wiring are ok, Look at the damper pulley on the front of the crankshaft. A common problem is the rubber pulley mounting goes bad so the pulley slips on the damper. Symptoms are very much like a loose alternator belt. Easy to tell. Mark a line on the pulley and damper with chalk, paint marker or silver sharpie. Go for a run and check to see if the marks are still in line.
jxjsv12 (08-09-2018)
Booty1313
12-23-2012 12:43 AM
Willchill
01-18-2011 08:39 PM
BrightonRay
11-30-2009 12:20 PM
riemann
XJ40 ( XJ81 )
10-03-2008 10:05 PM
