Battery dead, locked out of trunk 1995 xjs
I am locked out of my trunk and the battery is dead. 1995 xjs. The master key is not unlocking it. Can someone post a picture of where I can hook up a charger in the engine bay?
want to avoid drilling a hole behind the license plate but might end up doing that. Thank you.
Grant Francis (11-16-2023)
stran0020,
That's one of the terminals. I can't remember if that's the positive or a negative.
If you look on the other side, you'll see 2 terminals next to each other. One is +ve, one is -ve. Again, can't remember which is which. Put a multimeter on and you'll probably work it out. I can't beleive your battery will be zero volts.
(See attached pic for 2 terminals on Right Hand side of bulkhead. Remember my car is RHD so you'll see brake pedal housing in shot)
Paul
Paul
Thank you for the responses. I was able to open the trunk by using the existing license plate hole on the right hand side and sticking a long skinny screw driver in. The trunk popped right open and did not have to drill any holes. This was on a 1995 xjs not sure if this method would on older vehicles.
rickr (11-19-2023)
Mac Allan (11-17-2023)
Alphatrev
10-05-2019 09:16 AM
bobhoff
09-29-2018 08:14 AM
