Beeping alarm /flashing lights
Good afternoon fellow XJS fans
I acquired a 1993 4.0 XJS recently - and very good it is too. I love driving it.
However today I changed the battery, putting in a brand new battery and this seems to have caused the car to throw a wobbler.
When the ignition key is taken out of the ignition a beeping starts near the drivers right knee - quite near the instrument dimmer switch - and the headlights/brake lights/number plate lights all flash in time. When working properly the alarm will start ticking when the doors are unlocked and can be deactivated by inserting the ignition key. Now there's no ticking and the alarm appears to be deactivated.
The car starts OK and drives OK - I just can't leave it without the beeping and flashing - even when locked. So I've had to disconnect the battery until a solution is found.
Has anyone suffered the same issue? Anyone get any ideas?
Many thanks in advance
Rob
Rob
Not sure about your alarm type on the '93, but on my '92 5.3 when you reconnect the battery it will beep 5 times. This is so that l can program 5 remotes.....
So, connect the battery, wait for 1st beep then press remote button, 2nd beep press another remote. 3 beep if you have 3 press the button, If you have less than 5 remotes press 1 of them at every beep until it stops bleeping.
Hope that helps.
Hope that helps.
Ok,
Does key fob open the doors remotely ?
If not look behind the right (passenger) rear light panel in the trunk. you should see the base of the electric antenna and maybe a big white multi plug and a smaller black plug. There is a photo here
If they are plugged in (above pic isn't) you have the alarm. Its a black box located under the white plug in above photo. Horn is located behind the driver front headlight.
Try unplugging the white connecter, this will disable the alarm, remote locking and the beeping. If this does then your key fob is not talking to the alarm.
BUT, l think your model year might have a different alarm.
Alas that didn't work either. The fob has no control over the doors - the only thing it does do is create a different sounding beep when pushed.
The right hand rear light console in my XJS does look slightly different. I tried a few disconnections - as I would happily live without the alarm - but no the beeping and flashing continues.
Many thanks for your ideas - much appreciated
Hey there, I also have a '93 4.0, and I have suffered this exact same behavior.
Basically, the security ECU is pissed off about losing power, and won't shut up about it.![Icon Screwy](https://www.jaguarforums.com/forum/images/smilies/icon_screwy.gif)
I'd run my battery too low working on an ignition problem, and after recharging it, the beeping started. The short-term, get-this-stopped-right-now fix is to disconnect the security ECU. On my convertible, the security ECU is attached to the harness with a large block connector near the antenna in the right-side of the trunk.
The real trick is getting the security ECU back in a normal state, and unfortunately, I can't offer any magic bullets there. I ended up putting my car in a local shop that specializes in Jags and Rovers. They replaced my battery entirely with a high capacity unit, and was able to get the security system settled down by repeated operating the locks both manually and with the remote. At least, that's what they told me.
Is the remote fob not locking or unlocking the doors at all? That could make this harder to fix. My fob barely works at all; the shop had to clean it thoroughly and it's still pretty flaky, but they were able to make it work long enough to clear my fault.
Last edited by kurtomatic; 06-02-2013 at 11:58 PM. Reason: Expanded reply for clarity.
robsxjs (06-03-2013)
Yup, the range of the remote from new is about 1 foot,......... and the remotes antenna runs down the UK driver side only !! So really bad on the left side. Its the black plug. I had thought about re-routing it down the left side.
But it sounds as if robxjss alarm is a newer model, with a key transponder.
Just found this under the sticky
1. Turn ignition key ON.
2. Turn security switch OFF (located in center console).
3. Turn ignition key OFF.
4. Turn security switch ON.
5. Cycle security system switch ON/OFF rapidly 4 times (within 5 seconds).
6. Press each transmitter so a total of 5 confirmations are heard.
1993-94 XJ6 cars:
Hi Kurt,
I have a '93 XJS 4L convert with the same beeping problem. I would lke to disable the security system altogether since we live in a relatively crime free area and I understand that his is controlled by the white plug (with about 15 wires going into it) by the antenna but I also heard that unplugging this connector will disable other areas of the car.. Do you happen to know which other areas will be disabled? I like to use a battery cut-off switch for fire protection so it is an ongoing problem and I'm worried about disabling the ignition switch as well. Any ideas about this?
Thanks you for all your suggestions to Rob and myself- we all like our cars very much except for this annoying feature.
Jim S (stix66rb)
Jim S (stix66rb)
There must be someone on this forum who can tell us the different types of Jag alarms fitted to the '91 5.3 and 4.0 onwards XJS's.
My 5.3 facelift didn't come with the alarm or remote locking, just the wiring and place for it. So l bought 1. It just plugs in and out with the 2 plugs in the boot, big white 1 and the smaller black 1. When unplugged l loose the remote door function. But l think that the later alarms have a different setup with a transponder in the key and key lock. Try unplugging the large white connector and see what happens.......Might work or you just might get more beeping.
Did you try out the coding as l explained above ? works for my type of Jag alarm.
MY94 onwards introduced a new factory alarm system with a completely different operation. The 94 update pdf explains these changes also.
hope this helps a bit.
Allan
Well the beeping and flashing has been cured - more through luck and last minute exasperation than anything else.
Here's what I did (and yes it seems to be a hybrid of every comment above)
1. Unlock all doors and boot manually.
2. Disconnect the battery.
3. Leave for some time (I'd left it overnight)
4. Reconnect battery
5. Insert ignition key
6. Press fob five times in quick succession holding it close to the steering column. The bulb out warning light on the dash flashed five times
The beeping stopped!
Then deactivated the immobiliser as normal and car started.
Interestingly the central locking now runs off the fob which it never did before - even with a new battery.
Thanks to every one who offered suggestions.
