best aftermarket fuel pump upgrade?
Received 10,871 Likes
There are a few things you need to think of before buying a pump.
How much HP are you planning - this will let you select the flow rate.
How much do you want to spend
You could use a pump from anything with similar power to what you are planning or you could use Bosch or Walbro - 255LPH is good for around 500HP.
It does not matter if you go for a pump with too much flow as any additional will be returned to the tank. But going too small and the engine will lean out = CERTAIN DEATH.
