Best Repair Manual on the market suggestion
Hi everyone, I own 2 1994 xjs convertible with the 4.0 engine (Aj6) and I like to do my own work on them. I知 about to change valve cover gaskets and o rings but would like to know the torque specs for the bolts. So I知 Looking to purchase a repair manual. Any suggestions on the best one is greatly appreciated. I know Haynes doesn't make one for 1994 xjs but makes one for the Xj6 are they comparable on engine, transmission, suspension and rear end wise Thanks
Hi and welcome. I'm using the one shown in this link: https://www.ebay.com/itm/Jaguar-XJS-...wAAOSwCypWnsAY
and it is telling me that you are looking at 17-20 lbft for the cam cover ***'y set screws. You'll also need a half-moon seal for the rear of the cylinder head.
The 1994 XJ6 has the same engine and transmission but not suspension so the Haynes book may be of some use. You won't find a better resource than this forum though! (I'm referring to the expertise and magnanimity of other members).
Thanks MKii250 for the info. Will look into getting that manual. And thanks for the torque spec.
Jagfixer also thanks will do some research to get the factory repair manual can you post a picture to see what I’m looking for . Is the CD manual your referring too is that the same as the factory manual but in a cd format Thanks
Just noticed you have a six. There are a lot of other manuals available so you may wish to contact them. https://www.ebay.com/str/coventryfou...3017013&_pgn=2
Metaxalone
03-15-2016 03:24 AM
rama1200
02-07-2010 06:49 AM
