So my first test drive turned into a full fiasco.
I had new black fan blades, I bought new heavy duty clutch haydem 2747 ( which a lot of people were recommending as a heavy duty replacement for stock one) I trimmed the blades as clutch was a bit bigger then stock one.
after 10 mins of driving , with car at normal temperature and everything going smoothly, I pushed the throttle and blades flew off, rad killed in several places, coolant gone.
sure will recore rad, will get new blades, but why it happened? I can’t believe fan blades flew off because of clutch being a bit harder( because a lot of people on forums using it) could it be because I lost a bolt or nut in the engine bay and it got into the blades?
i Dont know now should I use Hayden or get back to stock one. Please advise.
AS OB said, the blades must have hit the cowl. Remember that the cowl is fixed but the engine moves on its mountings as it revs. Trim the next one a little more, and use a bandsaw or something that will not stress the blade as it is cut.
But what I do not understand is if the fan blades are OEM ones, why did they have to be trimmed at all?
I can't help but wonder if the trimming compromised the strength of the blades
could be, yes, but few things that makes it unlikely , basically everyone who using 2747 should trim blades, as clutch is a bit bigger and there is no way you can fit it without trimming. Also all blades went off not on the trim area.
and its bigger in diameter, so you have to trim innner parts of blades (mb 3mm) otherwise you cant use it, apart that it fits perfectly
how blades could hit the cowl? they are stock blades, stock cowl, and the only thing i have changed is clutch, so it wont affect positioning of the blades, the only difference with stock clutch as its a bit longer, so blades are 1/2 inch closer to the rad, but that shouldnt really affect anything.
also im examining the cowl and i dont see any signs of blades hitting it.
Ok, another clue, while removing rad I have noticed that I’m missing 2 out of 3 rubber seals from shroud, found several destroyed pieces of it . I can’t believe rubber piece can cause blade to brake , but who knows
This is the std black fan I fitted to my car with a std clutch.
as you can see the bottom of the blades are moulded with a curved sort of finish and the blades are thicker at the bottom where they are moulded into the centre ring. Looking at the picture of your fan and please don’t think I’m being rude but it looks like you just hacked the fan blades to fit the hub with a hacksaw or something and left it rough. I can only think cutting the fan to fit has weakened it causing it to fail. I would suggest a new fan and std clutch is the way to go. Mine works perfectly.
Rob.
I really hope that was the case ) but as I said everyone using this clutch had to trim the blades, mb I did it wrong. When you say std clutch which one you mean exactly?
NBC2215AA Is the part number for the std clutch. https://www.jagspares.co.uk/product/...a%2a1%2a%2a%2a
I purchased mine from David Manners along with the black fan. No cutting needed straight replacement for the original yellow fan and clutch. Works a treat.
I think by trimming the inner end of the blade (I had not appreciated that this is what you meant, I thought you had trimmed the outer end) you have done one of two things, or both:
weakened the root of the blade, and
set up harmonic vibrations in the blades that caused them to shatter.
I would buy the OEM setup as Robbo has shown above, and all will be well. XJSs with mechanical fans do not overheat if the system is on good shape.
Your first post photo now makes sense, the blades have clearly failed at the cut point.
Another lesson learned, thank you.
Im done with it, im going efans
3 clutches, 2 fan blades
Make sure they are SPAL or OEM quality ones (eg BMW or Merc) cheap ones cannot take the XJS under hood environment. Also make sure you have a clear understanding of how they are going to be controlled; Grant's system is the best one and very robust.
It is because airflow numbers are basically make believe! Bitter experience has proved this for me, only the amp draw is a reliable guide to the fan's ability.
