blade fuse question
blade fuse question
So as part of the work I've been doing on my cooling system I have replaced the belt driven fan with an electric one, and as part of that project I have decided to replace the little fuse box there in the engine compartment with a slightly larger one to accommodate a fuse for the new fan. According to this little chart 10 amp lucas fuses should be replaced with 7.5 amp blade fuses. If this is accurate my question is if I can't find a 7.5 would it be more acceptable to use a 5 or a 10 amp instead? I had gotten a little kit with a bunch of different rated fuses but 7.5 was not among them and my local stores dont seem to ever have any in stock, but I do have 5s and 10s in abundance.
I say use a 10 amp fuse, at least. There is a huge current draw on starting the fan. But I really recommend that you use a fused relay, powered from the firewall positive post. e.g.
https://mgispeedware.com/product/aut...elay-40a-spst/
the wiring kit for the new fan comes with the relay and appropriate fuse for the new fan. In replacing the little fuse box currently in the car there are I think 2 10 amp fuses. Since i'll be going back with blade fuses instead of the lucas fuses that are there now the chart says i should go with 7.5 but I cant find them so im wondering if 5s or 10s would work. I haven't looked at a diagram to see what these fuses are for.
this is the little fuse box I am replacing with one that takes blades.
