bleeding the rear calipers
Hi, I've still got my '82 xjs and the small elbow coming off the brake resvr was loose and sucked in air and now I think they'll need to be bled. Does the cradle need to come down to do the rears, or can I reach the bleeder screws with it up? I was told by a local caliper rebuilder that they should be 10mm. Is this also correct?. Thanks
anziobridgehead (05-09-2014)
Ooops! Might need to point out,
On my 87, the FRONT brakes are metric. Not sure about your 82. I have a feeling this thread will get to "speed bleeders" at some point. Pn the crows foot wrench, if its a little long, cut off the other side so you get about a 4 inch wrench. Now you have a "custom Jaguar tool"! Not going to be your last! ;-)
Richard_gib
09-12-2015 07:08 PM
philwarner
09-05-2015 10:05 AM
