Bra?
You should probably be ok without it, as winter has not started and there isn't the sand and salt on the roads yet.
I have seen the fabric bras flaps in the wind and wear away the paint in places, so you're probably better off without that. The 3M clear film certainly works, but isn't cheap. The problem with the low sloping bonnet of the XJS is where do you stop? There is very little that is somewhat vertical. It's expensive, so covering the whole bonnet wouldn't be cheap. If you ever want to do concours it's a major deduction as well.
Cheap solution: clay bar and ChemicalGuys jetseal (nano hydrophobic skin) applied by hand.
$1000 solution: clear wrap/ceramic coating
one is 50 bucks max, the other is not both last a while. If you have money to burn the bra skin is nice but not super necessary, a few layers of jetseal and a ceramix wax on top will do.
