Brake booster vacuum tank
Greg in France (06-07-2016)
use up all the vacuum on any particular stop.
Remember being able to pump the brake pedal 4 or 5 times before
getting a hard pedal when the ignition was off?
If you still have a 1973 F-body manual the description should be
in there. Failing that, a 1968 Ford manual.
It's in the booster itself. There is reserve valving. You don't
Apologies if you knew this, but the Lockheed vacuum servo on the XJS has that feature, as AFAIK, do all such Lockheed servos on all UK cars of the era. The XJS extra reservoir is in addition to that provided by the Lockheed unit itself.
Greg
Received 10,876 Likes
Thanks.
Yes, I was aware of there being a 'reserve capacity', so to speak, to the brake booster.
Earlier I thought you were referring to some sort of separate reserve storage.
Paul_59
04-03-2016 04:55 AM
FS[SouthWest]: Series I 1973 Jaguar XJ6 driver on BaT Auctions! (in OK)
Ipc838
04-01-2016 10:31 AM
Uncle Fishbits
03-24-2016 06:20 PM
