Brake caliper pins too short?
Old 10-07-2016, 11:02 AM
Asdrewq's Avatar
Default Brake caliper pins too short?
I got some new caliper pins today (JLM1539, aftermarket type: #TRW PFK141) & when trial fitted in the replacement caliper they look too short for me - is this picture correct?
All other cars I've worked on have the pins going through both sides of the caliper, with the locking clips being outside of the brake pad area. I would have thought the little locking clips provided could scratch/damage the piston seal?
Also I noticed my new (recon) caliper looks different to the original one - original has a large S & G in the casting - Are all XJS calipers the same?
I hope so as I probably won't be in a position to fit them for a few months at least as i'm replacing the subframe so likely too late to return
Old 10-07-2016, 11:40 AM
ptjs1's Avatar
Received 3,033 Likes on 2,015 Posts
Asdrewq,
That looks correct. They have a larger head which stops them going through too far and a small spring clip inserted through that hole on the inside edge of the caliper. The spring clip won't interfere with pads or the piston seal. Lube the pins with copperease or similar.
Good luck
Paul
Old 10-07-2016, 03:54 PM
BC XJS's Avatar
Look right to me too
Old 10-09-2016, 09:45 AM
JagCad's Avatar
Received 2,399 Likes on 1,880 Posts
The ultimate test, function!!! They do meet that test. Locked in place? Yup.
And, I agree, lube. I use high temp grease. "Just a dab will do ya".
Carl
MarlboroughMotors
06-11-2024 04:13 AM
absoluteze
04-26-2024 10:02 AM
wcourt3010
09-02-2016 12:40 PM
randyb
09-01-2016 02:08 PM
Tink
08-31-2016 07:41 PM
Quick Reply: Brake caliper pins too short?
