"Brake" dash light
Old 05-27-2014, 05:18 PM
SeanPeterLynch's Avatar
Default "Brake" dash light
On one startup yesterday "Brake" light went on. For a second I thought it was the "Park Brake" light. Pulled parking break and then released. "Brake" light went away.
Any ideas why this happened. Always sensitive to anything that comes to brakes, so wanted to check.
Old 05-27-2014, 06:11 PM
Steve M's Avatar
Received 3,036 Likes on 1,702 Posts
Obvious, but have you checked the fluid level?
Old 05-28-2014, 01:51 AM
Greg in France's Avatar
Received 9,331 Likes on 5,475 Posts
Not sure of your model, but on my car the dash brake fluid warning light goes on when ignition is first switched on as part of the factory startup dash light illumination test.
Greg
Old 05-28-2014, 07:19 AM
Bill C's Avatar
My "Brake" light was being set off each time I stepped on the brakes due to a bad Brake Accumulator. On page 457 of "The Book" you'll find more information on the accumulator, how to check it and tips on buying a replacement.
Old 05-28-2014, 08:21 AM
sidescrollin's Avatar
on my 88 (no ABS) this light comes and goes. It has come on when I first got the car because the brakes legitimately failed, but now it just comes and goes because the sensor is crappy. I usually ignore it.
Old 05-28-2014, 09:48 AM
Need to check fluid. Will try that for starters.
JarodL
03-07-2024 01:39 AM
Jpav27
07-31-2022 06:43 AM
jagent
09-12-2015 01:40 AM
mrplow58
09-09-2015 11:27 AM
02jagstype
09-04-2015 08:20 PM
Quick Reply: "Brake" dash light
