Brake Failure at 70mph Car nearly caught fire XJS V12 Help me please!
I expect all the grease has melted away as it must have got red hot!
If you do have the misfortune to suffer a fire make sure that you shut the engine off before discharging the dry powder extinguisher; if the engine is still running it will ingest the powder which then reacts with oil to turn into a nice acid which eats all the seals.
orangeblossom (05-18-2014)
Good!! I would also do both of the brake hoses while your in there that very weel could have been your cause because they are known too spilt suddenly (like yours) re tighten your e brake cable after its use and tray too find braided brake line for the front its a little stonger.
http://
![](https://www.jaguarforums.com/forum/attachments/xjs-x27-32/84649-brake-failure-70mph-car-nearly-caught-fire-xjs-v12-help-me-please-xjsapril30th004_zps5d5cfc82.jpg?dateline=1400451027)
#31
You need an all class fire extinguisher a b and c for fluids electric and materials such as carpet wood etc don't skimp! It will save your pride an joy someday! I have five in mine and its not even on the road yet! Two meduim sized ones a large one and two more med ones in the trunk the larger one is mounted up against the fuel tank the med ones are in the cabin one behind each seat .
orangeblossom (05-19-2014)
#32
How on earth do you expect to use 5 extinguishers? Have you also got a full fire suit and breathing apparatus because, trust me (from experience) if the fire is that big to warrant 5 extinguishers you aren't going to be within 50 yards of the car; your underwear will be on fire.
Hats off though for considering the possibilty and taking appropriate precautions.
Now, do you also carry a hard hat in case of meteorite strikes or unfriendly launches from neighbouring countries?
#33
The most obvious fire hazard is the open jar of marmalade (could be honey) with the wooden handled spoon behind the extinguisher; a classic explosion waiting to happen.
You left the top off the bottle of Absinthe; flies will get in and after you have had a well deserved drink post fire extinguishing adventure you go down with gastroenteritis.
Fire extinguisher insrtuction 1: Use Upright. What if you are lying on the floor and the fire is above you? Do you have to stand upright and put your head in the flames before you can use the extinguisher?
How old is that extinguisher? It's blue! It's got to be over a decade since all (and I mean ALL) shipboard fire extinguishers have to be red; with a tiny label on it denoting which particular fire they are suitable for.
That's right: you are crawling along a smoke filled corridor with your **** on fire, your glasses have melted and you have to stand 'Upright' to read a tiny label that has probably burnt off in the fire. So you give up, grab the closest one and attempt to extinguish the electrical fire which is feeding a broken oil pipe with a 10 gallon water extinguisher.
Also, if you happen to come across someone (this apparently did happen) who has just come out of a very hot fire whilst wearing a silver fire suit, don't hose them down; they will literally baste to death.
Funniest thing I ever saw on a fire drill? Still brings several tears to my eyes I have to say.
There may be some old seafarers on here who remember the dreaded 'Smoke Helmet'. Basically, seafarers were (still are in some cases) considered to be disposable assets so even though a shipping company complied with the regulations it was always at the lowest standard possible.
So rather than invest in proper SCBA (Self Contained Breating Apparatus) like what proper firemen wear, we had the 'Smoke Helmet'.
This looked like a proper face mask but it was connected to about 50 yards of wire wrapped 2" hose. At the other end of the hose was a large bellows, big enough for 2 men to operate with their feet, all beautiful varnished wood and polished leather (think the sort of size that you would use in a forge). So, the idea is that the hero (dumbass) goes bravely into the fire whilst his 2 mates keep him supplied with fresh air. Not get bored and wander off for a quick smoke (been there, seen that).
Aaaanyway, Singh puts the face mask on, Singh and Singh (Indian crew in case you hadn't guessed) start pumping away furiously, in perfect tandem, like a well oiled machine, and 50 yards of cockroaches erupt into Singh's face mask.
And I'm not talking little roaches here, I'm talking about the proper Bombay 6 wheelers. The mask was bulging with the pressure and there were all these legs and antennae wiggling furiously around the sides of the mask and the straps, desperatley trying to escape.
Obviously we tried to help but the other 49 of us were curled up on the deck, clutching our tummies and howling with laughter and/or vomiting.
Aah, the good old days, when men were men and women were glad of it.
The following 3 users liked this post by Steve M:
#34
I'm Towing a Water Bowser, have Smoke Detectors on All my Wheels and have the Local Fire Station on my Speed Dial!
#35
#36
#37
Should I be positive and say I am glad he drove his car with bad brakes and that it was probably a good idea?
Should I respond to the fuel thread praising the OP for ignoring everyones posts?
You are being negative about my posts because the topic or op did something negative. That isn't my fault
#38
#39
Yeah its a "free country" but that doesn't mean it was a good idea in any means.
I was one of the first to respond to his other threads with advice on fixing his brakes. That why my comments in this threads don't cover that. I was more surprised,confused, and disappointed to see he thought it was okay or safe to drive the car anyway.
If he is free to not fix his brakes why am I not free to comment on it being a bad idea?
#40
http://
How the Kinell am I supposed to get that lot in the Car!
If the GF Saw me wearing that, Then She would no doubt be thinking, that We were about to get up to something Kinky!
Which reminds me of when I went shopping for a New Double Bed where the Salesman asked me, if I wanted a 'New Headboard' to go with it?
When I said 'Yes' he suggested that I bought a Padded one, until I said 'How am I supposed to put 'Hand Cuffs' on That!
'I want that Brass One!'
To which he replied: 'I'm obliged to point out that its not Real Brass!'
Though with the kind of Girls that I bring home, I doubt if they would ever know the difference!
You are right about the 'Honey' but wrong about the 'Absinthe' as it's an empty bottle that I had left over from Christmas.
Which I keep just to remind me that the GF and the 'Absinthe' do not mix, as my GF Alice, or 'Hurricane Alice' as She is now better known, bought that bottle round for Christmas and ended up Wrecking The House!
As it turns out, neither of us had tried the Stuff before but you know what happened to Van Gogh, He had a couple of glasses, then went and cut his ear off!
And so We went the full nine yards with Cubes of Burning Sugar on the Top of the glass, which has a similar smell to burning Dot4! and if anyone knows what that smells like its me!
One shot of the Stuff is like drinking a can of Strong Lager but after 3 Shots the GF reckoned that it was well overrated and so after having another 3, said that all of a sudden, She wasn't feeling Herself!
Which makes a change!
So I told her to sit still on the Bed while I went and got her a drink of Water (which actually makes things worse!)
All of a sudden I heard a Crash and ran into the Bedroom, which was a scene of Total Devastation!
For as She tried to Stand Up, She fell over and then made a grab for the Curtains to steady herself and in doing so pulled the Curtain Rail out of the Ceiling!
Which then tipped over the CD Rack, which knocked the TV on the Floor and smashed it!
I haven't bothered to make a Claim on the Household Insurance as every time I make an attempt to fill out the form, I always end up laughing so much I splutter cups of Coffee over it.
Check out the Absinthe Videos on You Tube and see how a few Shots of this stuff can Mess with your mind!
Loved your Post! another one corrupted bring it on!
http://![](https://www.jaguarforums.com/forum/attachments/xjs-x27-32/84731-brake-failure-70mph-car-nearly-caught-fire-xjs-v12-help-me-please-xjsapril14006_zpsa947920f.jpg?dateline=1400506671)
http://
![](https://www.jaguarforums.com/forum/attachments/xjs-x27-32/84733-brake-failure-70mph-car-nearly-caught-fire-xjs-v12-help-me-please-homewreckerhurricanealice2_zps87ac599a.jpg?dateline=1400507688)
Now, I can spot a couple of problems with this picture.
http://
http://
LnrB (05-19-2014)
