Brake Failure xjs 1989 coupe petrol manual 3.6 ABS
Old 03-06-2017, 12:59 AM
Greg in France's Avatar
Received 9,247 Likes on 5,431 Posts
Originally Posted by Jeff Morris
Hi Gregg
to change the rear hub pivot bearings do i need to undo the drive shaft or is there enough movement when i remove the large pivot bolt
Are you doing a full rear suspension rebuild?
If you mean the inner fulcrum bearings that the lower suspension arm pivots on, and the inner fulcrum (rather than the outers) that is attached to the side of the diff casing; then the answer is yes, you do have to remove the long pivot rod that connects the diff bracket, the suspension arm and the axle cage, and thus free the suspension arm inner end to change the bearings. The bearings are set inside the eye on the end of the arm.
This is clear on the diagram:
https://www.jaguarforums.com/forum/n...eply&p=1632985
Greg
