Is this Brake Fluid all the Same?
Old 09-26-2016, 05:49 PM
orangeblossom's Avatar
Received 3,845 Likes on 2,662 Posts
Default Is this Brake Fluid all the Same?
Hi Guys
They are Both DOT4 but the Round Tin says 'Synthetic' while the other one does not, from what I can see. (Although it might be?)
I may not have enough in the square can and unless there is a difference may have to mix them.
The Round Tin is about half full and the square one about 1/4 full.
Going on past experience I will probably need to use all of it to thoroughly bleed the Brakes.
They are both DOT4 but the Tin on the right says Synthetic, though the other one might be as well.
Old 09-26-2016, 06:00 PM
Received 2,266 Likes on 1,845 Posts
All brake fluid is synthetic.
I wouldn't use any brake fluid from a previously opened container that's been sitting around.
The following 3 users liked this post by Mikey:
Datsports (09-27-2016), orangeblossom (09-27-2016), sidescrollin (09-27-2016)
Old 09-26-2016, 11:14 PM
BC XJS's Avatar
I agree. Don't use it if it's old. Brake fluid is hyroscopic. That's why it's important to change and flush the fluid regularly.
I buy smaller bottles so I don't have old crap laying around.
Old 09-26-2016, 11:17 PM
Jagboi64's Avatar
Received 3,210 Likes on 2,112 Posts
Always use new brake fluid from a sealed container. The only brake fluid I use that doesn't come from a sealed container is when I am using it as paint stripper.
Old 09-27-2016, 02:10 AM
Hi Guys
Thanks for you help Mikey@Jagboi@BC XJS.
I've just found a Full unopened Tin of DOT4 like the round one, which should be enough.
OzXFR
09-27-2017 08:15 PM
Lawrence
XJ40 ( XJ81 )
17
10-31-2016 12:20 PM
TJChid
10-17-2016 05:45 AM
Rob XKR
10-08-2016 11:27 AM
hirev
09-25-2016 10:23 PM
Quick Reply: Is this Brake Fluid all the Same?
